G550 Windshield antenna leak
Old Aug 13, 2024 | 01:21 AM
Quis's Avatar
G550
My 2016 G had water leak through the windshield keyless antenna seal and it caused $8000 repair estimate REMOVE DASHBOARD / REPLACE INTERIOR BUS BAR / RE PIN BUS BAR / REPLACE ANTENNA AMP / RE PIN KEYLESS GO ANTENNAE / REPLACE WINDSHIELD SEAL AND TREAT RUST BENEATH SEAL
Old Aug 13, 2024 | 09:14 AM
streborx's Avatar
Top Answer: 1
G550
Original glass or did you have the windshield replaced recently?
Old Aug 13, 2024 | 10:29 AM
Quis's Avatar
G550
It’s the original glass
Old Aug 13, 2024 | 06:14 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W463 forum...
Old Aug 13, 2024 | 10:38 PM
WagenAddict's Avatar
w461/w463
Dash removal is major labor.
So what sort of issues did the leak cause?
Old Aug 14, 2024 | 01:14 AM
Quis's Avatar
G550
Every dash light came on, engine light , etc…and then then once turned off, the car wouldn’t start again. Apparently the key less lock antenna communicates with all the other electrical functions and so it won’t send a signal to start the car. I don’t even have key less start…but now it’s all corroded and rust.
Antenna through front windshield
Old Aug 14, 2024 | 02:02 PM
95_993's Avatar
G63
Yikes!!! Good to know and another thing to keep an eye on. Assuming if the leak was right at the windshield, it could be caught early eliminating the need to remove the dashboard
Old Aug 14, 2024 | 02:38 PM
Quis's Avatar
G550
Yes- it seems like a significant design flaw. I don’t think they do it in newer models.
