PPF or no? Platinum white metallic G63
Thoughts? I want to have worry free driving. I’m fine to do it but would rather save my cash if it’s not worth it or a pain to deal with?
I also have a slight fear of someone taking apart the truck.
A good installer of PPF shouldn't have to take any parts off other than the brush bar which is easy. A wrap is a different story though.
I also go back and forth with PPF but did a full front on mine. I'm glad I did since I'm keeping it a year longer than initially expected.
If you do a lot of freeway/highway driving then it might not be a bad idea. It will also depend on what the roads are like where you are. We get a ton of debris on the roads around here. I've been through 5 windshields on 3 different trucks in the past 3 years around here, but some people don't end up having those kinds of issues. What I have noticed is that the front hood edge on all of these trucks is relatively unscathed. The grilles have a few chips though. If you mainly drive on lower speed roads then the PPF might not be that necessary.
I have been debating whether to do this or not also. I have done other cars of mine - it's fairly expensive but does give you peace of mind. Just make sure you get one done that is pre-cut. Don't let a knife anywhere near your car - they will cut the paint eventually. For the new G, I am wondering if the most needed area for PPF is actually the leading edge of the rear fender flares. This area seems to pick up all the debris from the truck's own front tires. For those of you with some mileage on your car (and no PPF), do you see pit marks on the rear fender flares ? I'm wondering if a small piece of PPF needs to go on here just like 911's have a small piece covering the rear wheel haunches. Thoughts ?
It’s a tough call. I have a two other dailys so this is part of my occasional joy car fleet among others. So not a ton of highway miles at all. Not sure if it’s worth the spend for full ppf for that kind of utility.
'19 G63 Ed 1,'18 M5, '16 G63,'12 458 , '11 E63, Brabus SL55-K8, '10 S63, '94 E500 "Wolf", '91 560SEC
If you are OCD about rock chips go for it. Otherwise, it does zero for resale or even recouping the cost of having it done.
I have mine ceramic coated including the wheels. I had PPF on my entire GT3, but it sat so low to the ground, it was a must. I had a rock hit the hood on the highway. If you had matte paint, I’d say PPF for sure, I don’t think you need it with metallic paint.
Jagdpanzer (12-24-2021)
I am with you on having someone taking stuff apart and having a little issue. Or damaging something else when trying to do it. I had it on a 911, on the full car and hated it. The stuff always had an edge working up somewhere. I have had it on the last probably 5 cars and am done with it. All from different installers too. Even with wrapped edges it's a pain, at least it was for me. It seems impossible to get it down and not find an air bubble or some contamination somewhere under the film that is forever trapped. A gal friend of mine had a 911 as well and it had the whole front end done. Well she got a rock chip and it went through the film and got to the paint. So then she had to pay the body shop to remove the film. Problem was that it was on for so long that when they got it off, it left a glue residue on the hood that had to be wet sanded off. At that point you are paying for the removal, losing clear coat from the wet sanding, then paying to put it back on if you decided too. A fine artist brush and a little paint is what I do now. I have also had body shops feather in some spots by hand with a drop of paint, a drop of clear and wet sanding and polishing. It's not that noticeable and it saves a lot of money. Plus you don't have to detail with special soaps or waxes. And when you do detail you can actually feel the smooth paint instead of plastic. I am only going to ceramic coat my G63 and thats it. I will do that myself too. The only finish I would PPF is the matte finishes because they are so fragile compared to the regular paints. This is just my opinion and do as you wish. Save your money and use it toward the next trade. They are not going to ding you if a few paint chips have been filled in. Maybe on a super car but not on a G in my opinion. I just back off the traffic a bit, and when I pass big trucks I slide over a bit for possible spray. Not only the paint but saving that windshield. If you are in a high gravel rock prone area, it might be worth checking into. It's all what you decide and there are good and bad points. For what some of the installers charge, its almost like you paying to have it painted anyways. The last thing I forgot to mention is white. I hated it when I had film on that color because the edges of the film always showed dirt lines.
The following 2 users liked this post by Jagdpanzer:
michelleMB (12-24-2021),
PeriodCorrect (12-24-2021)
I 100% agree. After a lot of thought and looking into it I’m just doing ceramic coat and that’s it. The worn film and dirty edge look to me is much worse than rock chip blemish that can be fixed if needed.
The following 3 users liked this post by Eply458:
You”ll have the most protection with combination of PPF topped with ceramic coating. A good quality clear mask will give some insurance for road debris and small rocks. Front hood, fenders and mirror housing benefits the most. Ceramic coating keeps the car looking cleaner, easier to maintain and wash and enhance the color. Protection is there from minor scratches. To me matte finishes being hard to repair, should have at least one or the other. On cars I care about I do both, the ones intended to leave the household within a year, I minimize that expense. Leased cars get none. Enjoy your ride.
When I had it on my last car I found a bit of contamination between the film and the paint. I said what about the lil air bubbles. He goes oh we will use a syringe to get those out. And what about these couple spots. Oh thats probably dust in the air lol. He said it was next to impossible to get it on without one lil issue here and there. And then there are the types that use razors to trim. No thanks, we are only human and there is a reason they put erasers on pencils. I think PPF is great for certain apps, but in my opinion its not for me. Maybe it will be for the next person.
I do as well. I have the ceramic and will be doing paint correction in my garage in the next week or two. I love doing my own stuff if I can. Listen to the radio and drink a pop. Good times (: Really I will just be claying it off and applying the ceramic. The paint is not swirled or messed up in any way. Will do the wheels last
Driving home from work today and saw a dime sized rock fall vertically and innocently against the windshield and thought huh that’s weird.
Found point of impact on front edge of hood. Now question is do I bother fixing it which requires new hood PPF then opti-coat on top or let it ride.
Really glad it didn’t hit windshield directly at least.
Jagdpanzer (12-28-2021)
Yeah I agree--I'm leaning that way to get it fixed--it looks like there's a small chip under the PPF after all.
Kinda leaves me at a crossroads--do I even bother with PPF in the future if I get rock chips anyway, or how bad would this have been without the PPF?
I've sent pictures to my installer to see what they think. Will keep you all posted.
I think PPF is good if you want to change the look (ie stealth or pearl effect like some of the newer PPFs). But paint protection? I dunno if it makes too much sense. I personally don’t know of anyone who has changed out their ppf after it started to show wear, scuff and trapped dirt. Whereas I know plenty more people who have done paint correction/wet sanding for different paint related issues.
the amount of paint “work” that’s needed when the ppf comes off is effectively a full paint correction procedure.
Interesting, I never knew they did PPF films in stealth etc as you mentioned. I had a white pickup that I drove over the winters and that front end took a lot of gravel. I got a small camel hair brush and a paint pen and in 30 mins filled like 20 small chips. And honestly it was hard to tell unless u were looking for it. White is pretty easy! I know this might sound dumb. But where I live now in the midwest, it is still good roads with no gravel on them since there has been little snow. I just got my G63 near two weeks ago. Well here comes the dumb part maybe to some. I will garage it before the big snow they say is coming this Saturday and will keep it garaged until spring. I have a pickup to drive and figure why mess that G up. I will detail it soon in ceramic in my garage and have it waiting pretty in the spring. IF it was the only thing I had available to drive then so be it. I am going to use it but with the mindset of no salt and gravel and the possible broken window or sand blasted front end syndrome come spring. (:
