G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
Max Tire Size? W465 w/ Offroad Package
Old Dec 27, 2025 | 10:48 AM
rossgivens's Avatar
2008 C350 sport
I just took delivery of a 2026 G63 with Off-road Pro package. The only available wheel with this spec is the 20” which I like more than I thought I would.
But the tires just look undersized to me. I’m thinking about doing Ridge Grapplers which have a much more aggressive sidewall.
Does anyone know the max tire size I can run without any rubbing? Factory size is 275/50r20. 285/50r20 seems like a safe bet, but I’m wondering if anyone has done larger. Also thinking about 21mm wheel spacers for a slightly wider stance.
Thoughts?
Old Dec 27, 2025 | 08:34 PM
Hodog16's Avatar
2026 G63
Wow that's a great looking G63! Congrats on a unique spec for sure--stop making me consider Desert Sand for my next one .
For the W463a I found that 32.1" tire diameter was just small enough to fit without rubbing without modifications.
I'm unsure if this translates to the W465 but based on that you have some room to go bigger.
Old Dec 27, 2025 | 09:11 PM
rossgivens's Avatar
2008 C350 sport
As one of the most prominent contributors in this forum, I appreciate your input. Good to hear that 32” will fit. Factory set comes out to 30.9” so it sounds like I have a little wiggle room. And thanks for the compliment on the truck.
Old Dec 27, 2025 | 09:24 PM
rossgivens's Avatar
2008 C350 sport
Based on the 32.1” you ran on 22s, I should be able to run a 305/50r20. Same 32.1” diameter but a hair wider. Would wheel spacers make it a tighter fit or give me a better chance of it fitting?
Old Dec 28, 2025 | 08:11 AM
The Butcher's Avatar
G63, G65
Wheel spacers will make it slightly more likely to rub on the front inner fender liner, but you can probably get away with little to no rubbing if you keep the max tire size at 32". I know everyone loves Ridge Grapplers, but it's not really the best riding tire and they tend to get noisy pretty quickly. There are other options out there that ride better, and will stay quiet longer than the Ridge Grappler. The Toyo RT Trail is one of the options to consider.
Old Dec 28, 2025 | 09:40 AM
rossgivens's Avatar
2008 C350 sport
yeah I’ve had a few sets before but never on a G. I should probably do the Recon Grappler instead in a 285/50r20 (31.25” diameter) just to be safe
Old Dec 28, 2025 | 07:02 PM
Need Speed's Avatar
2026 G 63, 2025 McLaren Artura Spider, 2026 E 53 Wagon
Great build and color - looks amazing with the offroad setup. I just put NITTO Recon Grapplers (285/45R22 on Vossen HF-2 wheels) on my 2026 G 63 for the winter and they ride great - there is some additional road noise vs. the summer tires but nothing harsh or loud. I also like the chunkier look of them on the G 63.
Old Dec 28, 2025 | 07:14 PM
rossgivens's Avatar
2008 C350 sport
I bet that looks phenomenal. Can you post a picture?
Old Dec 28, 2025 | 08:34 PM
Hodog16's Avatar
2026 G63
I had Ridge Grapplers, but if I ever do A/T tires again I'll do the Recon Grapplers.
I never had the Ridge's long enough to hear loud road noise but plenty warned me about it.
Old Dec 28, 2025 | 08:37 PM
Need Speed's Avatar
Here you go….I have black monoblocks with summer tires that I was going to put on once its warmer but I may just keep these on year round.
Old Dec 28, 2025 | 08:46 PM
rossgivens's Avatar
2008 C350 sport
Yea those look great. Thanks for sharing
Old Dec 29, 2025 | 05:08 PM
RedPill's Avatar
2025 G63MB, 2022 G63MB
operation desert storm..nice color!
Old Feb 8, 2026 | 04:18 AM
Sims123's Avatar
I have BF Goodrich K02 285/55/20 on G63 - they are stunning in all conditions. Put almost 60'000km on it.
If you consider serious overlanding/offroad, this is almost a must.
Old Feb 8, 2026 | 09:07 AM
rossgivens's Avatar
2008 C350 sport
I ended up going with 275/55r20 Nitto Ridge Grapplers. It makes sense you fit 285 KO2's since BFG tires notoriously run small.
Old Feb 8, 2026 | 12:29 PM
Hodog16's Avatar
2026 G63
That looks great! Did you change the spare tire as well?
Old Feb 8, 2026 | 12:46 PM
rossgivens's Avatar
2008 C350 sport
yes
