Was jus waiting and here it is ABS/ESP failure (now permanent)
Subscribe
Dec 24, 2024 | 10:54 PM
Hay all,
it just used to be intermittent, but now is permanent. Turning on and off the ignition ain’t helpful- faulty code is still here.
checked the fuse box by the driver side- all seemed to be okay.
Big socket by the ABS pump- all the pins are clear and seems to be okay. Plug and socket looks good.
Any other ideas where to look?
(patient: G 55 AMG 2011)
Reply 0
Dec 24, 2024 | 11:02 PM
Reply 0
Dec 26, 2024 | 03:39 AM
Any sort of ideas what that could be?
Also the speedometer is not working.......
Reply 0
Dec 26, 2024 | 09:26 AM
With DTCs reported as communications faults and now no speedo, I'd inspect for wiring damage. Any evidence of rodents snacking?
Reply 0
Dec 27, 2024 | 05:42 AM
Quote: With DTCs reported as communications faults and now no speedo, I'd inspect for wiring damage. Any evidence of rodents snacking?
hey, thanks for the hint.
No, no evidence of such a thing.
Also yesterday after a bit of a drive, problem is gone. Car repaired itself.
LOL
Dials started to bip. I Stopped on a side, turned off the engine, started again- no faulty codes on a cluster dash. Everything works ok.
But am pretty sure it’s gonna come up again…
Reply 0
Dec 29, 2024 | 12:53 PM
And today it did.
Getting crazy with that issue...
Reply 0
Feb 22, 2026 | 11:18 AM
Dear friend, I am having the exact same issues/faults on my ‘11 g55amg.
Neither dealer or specialist shop could figure it out yet. Did you have any luck finding the solution?
thanks a lot!
Reply 0
Feb 22, 2026 | 01:16 PM
Yes. It was a ABS control module…: managed to repair it but usually u gotta buy new one.
Don’t ask about a price.
Reply 0
Explore
Feb 22, 2026 | 02:24 PM
Quote: Yes. It was a ABS control module…: managed to repair it but usually u gotta buy new one.
Thanks a lot for the fast return and help!
Unfortunately, we already replaced it a few months ago ($$$), but issue came back! Maybe some short circuit or bad wiring?
You repaired only the module itself and after that, all clear?
Can you please share the contact of the place where you fixed yours?
thanks again!
Reply 0
Feb 22, 2026 | 04:00 PM
thanks again!
i am located in Poland so that could be quite difficult. But yeah the black part was repaired and since than problem is gone.
Can u provide with more of a details what’s going on there?
Reply 0
Feb 22, 2026 | 05:45 PM
Quote: i am located in Poland so that could be quite difficult. But yeah the black part was repaired and since than problem is gone.
Thanks again!
I am located in Brazil, so pretty used to get parts and services overseas LoL
When the car starts, usually AAS “consult workshop” appears and sometimes the engine fan starts working even when the car is still warming up.
Some days only these two happen and on other days I have several warnings such as yours (ABS, ESP, speedtronic, brake distribution, display malfuncion, check engine light)….pics below.
Dealer suggested the ABS module replacement but still the same issues. Now they are thinking about sending a support request to the factory.
Reply 0
Apr 12, 2026 | 07:15 PM
Strange (and good) update but, researching, found out that there were cases about key communication failure. I switched to spare key (brand new) and no more errors! 🙏🏻🙏🏻🙏🏻 one month daily driving it and zero warnings so far….
Reply 0
Subscribe
Currently Active Users (1)
