General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Home Oil Extractor
Old Mar 27, 2002 | 12:51 AM
Tony De Mattei's Avatar
2002 C230K
Quick Vacuum Home Oil Extractor
Hello all, Have any of you tried this oil extractor device sold by Griot's Garage?
https://www.griotsgarage.com/search...x=29&search.y=8
The cost is $69.95 + shipping.
Old Mar 27, 2002 | 01:24 AM
awiner's Avatar
2003 CL55 AMG
Re: Quick Vacuum Home Oil Extractor
That is the one I use and I love it.
Old Mar 27, 2002 | 01:25 AM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Not sure about the c-class sedans, but the coupe's engine requires 7 liters of oil, whereas this extractor can handle only 6.5 liters... A little inconvenient, having to dump some oil and then repeat the procedure on the remaining oil...
Old Mar 27, 2002 | 11:04 AM
KWiK's Avatar
2002 C230 : 2007 C230
Check out the link below, It talks about oil extractors and the one by BDM would actually do for home use.
Oil Extractor Thread
Old Mar 27, 2002 | 11:38 AM
awiner's Avatar
2003 CL55 AMG
Vadim is right. I need to empty a little off halfway through.
Old Mar 27, 2002 | 02:01 PM
Randy B's Avatar
**SOLD***2003 E500
Thumbs up
I have the same extractor. Yes, you do have to empty it out twice. However it is really nice and convenient. And the E-class uses about 8.5 quarts with a filter change. I have used it to drain the transmission, and transfer case on my 4X4 Expedition as well. Really nice tool, and well worth the money spent.
Old Mar 27, 2002 | 04:15 PM
awiner's Avatar
2003 CL55 AMG
Yes ! And you can get the "Brake Bleed" line setup from Griots and use the extractor to bleed your brakes too !
Old Mar 27, 2002 | 04:27 PM
Randy B's Avatar
**SOLD***2003 E500
Actually Adam, I Have a better setup for bleeding the brakes. I use the high pressure ABS motor to bleed them for me with a jumper wire and the nitrogen gas charge on board. Learned that trick on a XJS. The car has the capability of 300psi self containined. And it bleeds the ABS unit at the same time. Really bleeds them easily, and no pedal pushing involved.
