GL450 Issue Continue....
When I arrived there, I purposely press the STOP engine button while I am in "D" mode. It will not give me any red warning message at all. While in D mode, and the engine shut off. The car will slide backwards. If you are down hill, I am sure it goes forwards. And this will not engage to the "P" park mode automatically. My car just keeps sliding backwards as you can see on videos.
http://youtube.com/watch?v=Z5M-fcXUoBs
I also posted it at benzworld.org and someone told me to press the button on my car at highway speed and let us know what happened. I am afraid something might happen hehehe.
This is the replied from another viewer:
It seems the vehicle would stay in drive if you hit the keyless go button while driving, but the engine may cut off. If you notice, there's an arrow that appears in the dash that shows what gear options are available with the current vehicle speed. The one next to "P" goes away once the vehicle starts moving, so that seems to me that the electronic control of the transmission will prevent the vehicle from going into park. I don't know how (or if) it would be different when you're already stopped. It seems like it should stay in "D" like any other car would when you turn off the engine.
I tell you what, why don't you press the button on yours at highway speed and let us know what happened. Deal?
So i am sure we both consider it as a safety issue
Here is my baby wahhhhhhh. My first baby. She brings me lots of joy.
http://youtube.com/watch?v=SL5_cm6-jk4
PS: When there is no traffic, I will ty that in the parking lot. Turn off the engine while I am driving in "D" mode. Lets see if it shows me the message on the dash.
Well, I think if I am driving the car, and if I open the door all in a sudden, it will show the red message on the dash. But just not when I stop the car, turn off the ignition using the keyless go button.
I don't see a reason why would that offer such feature like allow us to stop the car with the "P" mode. The car can still move. Can you imagine we park the car on the slope. And by accident we press the stop button and get off the car, we will either hit a car, people or anything. That is extremely dangerous.
Why my other car like the 2003 E500 doesn't act like that? That has keyless go also, and it will not allow me to stop the engine while in "D" mode.
Regards
Cedric
Say you move your leg around, and you bump your knee into the KG button....what would happen if the car went into Park immediately, while on the highway. Not a good thing is it?
But I think sfxghost from benzworld already answered my question. After the meeting I will go outside and try that.
I already called my sales and he said "REALLY, that is odd. That should be happened. He was shock too. Now he is going to talk to the technican about it and let me know what happen.
And here is the other person replied to me.
What you are seeing is documented behavior.
On cars with KeylessGo, you need to open the driver door in order for the transmission to automatically shift to Park. On cars with SmartKey only, you need to remove SmartKey from ignition for the transmission to automatically shift to Park. I think both of these features are implemented so you could turn off the engine and have the car pulled through the car wash.
Here's what the GL 450 manual says on page 192:
Quote:
KEYLESS-GO*:
Keep in mind that turning off the engine using the KEYLESS-GO start/stop button alone will not automatically shift the transmission to park position P. Only when the driver’s door is opened, will the transmission automatically shift to park position P.
Even though this is possible, make it a practice to always shift into park position P before turning off the engine and removing the SmartKey from the starter switch, or when using KEYLESS-GO*, before turning off the engine with the start/stop button and opening the driver’s door.
Here's how the SmartKey works:
Quote:
SmartKey:
If you turn off the engine using the SmartKey and remove the SmartKey from the starter switch, the transmission will shift to park position P automatically. Keep in mind that turning off the engine with the SmartKey alone
One of the posts says if you open the door it goes into park, well that makes it hard to get out and have the car roll away.
I don't have keyless go, but if I turn off the via the key whilst in drive the engine turns off and if I pull the key out it goes into park. If the car rolls out of control while I am behind the wheel I would say that is my fault.
Am I missing something? I mean, if you leave the engine running, switch to neutral and take your foot of the brake the car will roll too.
I think I see what you are saying after some more thought. It is not that it doesnt go to park that you take issue with, but the fact that it is no longer in drive. From your description it behaves like it is in neutral. I agree that this seems odd, however the 7G probably needs power to hold and engage gears unless in Park.
I was always taught never to rely on an automatic gearbox holding gears on a steep hill in any case. For that matter I have had manuals that slip out of gear on very steep driveways.
I dont agree however with other views that the engine shouldn't turn off, of course it should if you are stationary. But I don't see a reason for not going into park once turned off. Would you ever want the car sitting in drive with the engine off? You can't restart from there (it tells you to put in park).
So in the end I agree with you.
But for this GL is totally different. Once you press the "STOP" button in "D" mode. The car will still act like in Neutal , it can slide back and forward. If someone behind me, that could cause an accident. Or you might hit something.
I know once you open the door, it will engage to "P" mode. But what if we are still inside the car and not ready to get off yet.
EFant - I can definitely live with that no problem. But just wonder why the setup is different than other cars.
At least show us the red message. With my 2003 E500 keyless go. Everytime I goto a car wash, I give them
the smartkey
Anywanys, I think thats the way they built GL. I am doubt that they will re-program that. May be the next batch or a year later.
So far I like the car very much, feel solid, doesn't feel like driving the SUV. And this GL plays mp3 and ipod.
But this is not really my type of car, but when you have kids, this is GOOD
I agree if you can't remember to put it in park before you shut it off maybe you shouldn't be driving.
That mentality is one of the biggest problems with this country, take responsibility for your actions and don't blame the car for its inability to protect you from yourself.
they should enable KG button ONLY when the gear is in "P" and disable it at all other times... not very hard to do i assume...
