AMG Pedal Kit
Now the problem...the kit does not apparently fit the 550. The gas pedal is completely different. It has a large piece of plastic on the back with mounting holes. The emergency brake pedal also appears to be wrong. It is only about a half inch thick and the current one is about 1 1/2" thick with some kind of metal rivet on the side. The brake pedal appears to almost fit and it may just need some more pulling to get it over the metal pedal.
It looks like I got screwed by eBay.
Any constructive comments are welcome. The stock # for the gas pedal/ emergency brake is A 170 300 00 04. The brake pedal # is A 170 290 01 82.
Bummer NJ, ..... the only constructive comment I can make is that it's not Ebay that did the "screwing" it was the seller and there seems to be more and more of that on Ebay. I used to be a big seller and buyer on Ebay but have back off considerably. If the kit fits the 450 you might find a buyer on the forum.
I am not sure what to tell you, NJ. I will take a look at one of 550s pedal when in Vegas and see if my pedal kit would fit. Bummer...............
The gas pedal slips over the existing gas pedal. The emergency brake and brake pedal covers need to be removed first. The brake pedal comes off very easily. I broke the plastic pin on the original emergency pedal taking it off, but the new one has a rubbery one that fit in the hole just fine.
The amg gas pedal slides over the plastic gas pedal. You don't remove anything. The emergency brake pin needs to be pulled out and the cover comes off and amg pedal goes on. (It has its own rubber pin) The brake pedal gave me the most trouble but it went on with some cursing and patience. Same deal take the rubber pedal off and slide the amg pedal on.
can you please take some pictures of the backsides of the pedals? thanks in advance.
Was there a special page for the GL or was it included in the one listing all the cars without the GL on the list?
I'm off to the east coast...see you guys on line along the way.
You and your sister will be in my and my family's prayers. Have as good a trip as can be expected, under the circumstances!
STP
