Suspention "clack" while going over speedbumps
just got my GL 450 about 1300 km back and like the car. With exception of the "man-made leather" (didnt have other option with the pre-configured 450 over here i Dubai) I think its a good car.
One thing though strikes my attention: I drove a Range Rover before with Air Suspention, and it was very smooth and without any noise while driving over bumps etc. Actually the Air suspention was one of the reasons I went for the GL. The GL is smooth but sometimes noisy.
To make a long story short, while driving over speedbumps or over bumps on "offroad", I get a "clack" noise whenever the suspentions expands. It sounds like a top end limiter "clack" or like the shocks were loose. I know that cant be the case anyhow its anoying and differs heavily from the Rangerover and it happens without driving extremly fast or harsh.
Do you guy also have that noise?
Tom
lkchris - what is the Startuned service bulletin? Is it official MB? Will the dealer know about this?
the StarTune Info seems to fit -- makes a lot of sense, had a similar problem in another car (Stabilizer loose).
The sound happens with the car in comfort and without having it liftet. Will see what MB tell me about the Startune info.
Many thanks and keep you posted once its gone,
Tomi
- perform open campaign on:
power steering gear box/steering rack , r&r
thrust piece and rack (steering removed), adjusted play
- spray wax on front axle bushings
- tightened sway bar end links
- removed steering rack and adjusted radial play in steering rack
- replaced strut assembly - left front air suspension
- replaced stabilizer bar
Invoice lists the following description (all covered under warranty):
Fuse-specify location, replace
ADS control module, replace
Control unit, replace
airmatic control unit as per DTB T-B-32.22/66D. Replaced ECU.
Pulled fuse as per diagnostic procedure of DTB, road test. Noise is gone now. Replaced airmatic control unit wuth updated version per DTB.
