A/C Problem 09 550
Old May 12, 2010 | 11:17 AM
Shellbmb's Avatar
14 GL550; 14 E63s
A/C Problem 09 550
Has anyone else had issues with their AC cutting in/out? We've already had a few mid-90 degree days here in Texas, so this is not good with two small kids in the car.
Took it in and they first tried to replace the compressor---no luck. So now they are having to order some wiring part from Germany and not sure how long it is going to be. Already been a week.
The loaner C300 is no GL.
Old May 12, 2010 | 11:37 AM
sang55's Avatar
K3 05 E55 sold, 09 GL550
The AC of my GL550 is fine but sometime I got AC blow out on 3rd row seats and sometime its not and I don't know how to do . Anyone know please help.Thanks
Old Jun 21, 2011 | 08:48 PM
Camille G's Avatar
GL320 cdi
a/c problem
I am in Houston also and my GL is having the same problem. was the problem fixed on yours?
Old Jun 21, 2011 | 10:46 PM
Shellbmb's Avatar
14 GL550; 14 E63s
Yes, it was fixed after they replaced the part. I think it ended up being one of the panels or switches on the front that was defective. Replaced under warranty and it has been fine ever since.
Old Jul 30, 2011 | 12:38 PM
drshred's Avatar
BMW x5
ditto here 09 450gl. on and off AC taking it in this week. keep u posted
Old Jul 30, 2011 | 10:59 PM
Camille G's Avatar
GL320 cdi
Smile I think was fixed
I picked up my gl up friday for the second time. The first time they said they replaced the switch panel and this week a new compressor so far so good.
Old Apr 13, 2017 | 11:32 PM
kismetcapitan's Avatar
GL550
bringing this up again - my '09 GL550 blows cold on the passenger side; lukewarm at best for the driver and the rear. Sometimes, I get a rare blast of cold on the driver's side. Seems to me like an issue with the ducting between heating/cooling, but have others gone through this only to find that it was the climate control switch panel?
Old Apr 13, 2017 | 11:37 PM
gl450x164's Avatar
gl450 530i
actuators for the blend doors
Old Apr 13, 2017 | 11:55 PM
GL550
that's the word that was on the tip of my tongue, the little servo motors that control the blend doors. Ten years ago I lived overseas and had a Nissan Skyline GT-R; the blend door actuator failed and I never bothered to fix it. I disconnected the control arm and just reached down and flipped the door by hand.
But I'm older and lazier now; everything better damned well work by the push of a button!
Old Apr 14, 2017 | 01:51 AM
GL550
it's not mechanical, at least it appears that way. It's nighttime and 71 degrees ambient. I started the car, and was hit by a veritable ice storm of air. same temp all three zones. I waited until I was literally shivering, to confirm that it was well and truly cold, then I cranked the heat and warmed up. It got all the in-between temps too.
so where are the temp sensors, that are clearly only operable at night?
Old Apr 20, 2017 | 02:21 PM
GL550
dealer found a pinhole leak in a hose that was leaking, but not when the hoses weren't hot (like at noon on a hot day). Replaced and recharged at no cost to me.
Old Apr 20, 2017 | 07:42 PM
GL550
evening update - ran the car all day in blazing sun. couldn't get any colder. funny how much one leak can cause one to pull out their hair in stress (the Wife)...and pressure me to fix it! lol
ETA: it's frustrating when people post a problem, then don't post the fix or how well it worked. Hence my updates~~
Old Apr 24, 2017 | 04:59 AM
SFCabs's Avatar
2008 GL320, 2008 CLK 350 Cab, 2004 CLK 320 Cab, 2010 BMW Z4
I'm having similar issues. I'll look for a leak but someone else suggested blend door issue. Wouldn't this create an error code? I didn't see one in STAR.
Old Apr 24, 2017 | 08:10 AM
gl450x164's Avatar
gl450 530i
run the actuation
