Will 285/55/18 or even 285/60/18 fit instead of 265/60/18
Old Nov 22, 2010 | 06:06 PM
valter's Avatar
GL450
Hello everyone! New member here. I apologize for another tire thread
I need to change tires before white stuff starts falling... I was thinking with getting slightly wider tires, as stocks 265/60/18 looks mighty thin (in my mind lol)
Anybody successfully mounted 285/55 or even 285/60 on stock wheels with no rubbing/other issues?
Looking at these Nitto tires....
Old Nov 22, 2010 | 06:18 PM
HamMan's Avatar
2015 E400 Cab - 2013 GL350 - 2013 ML350 - 2006 E350 - Old Jeep
Yes, 285-60-18 fit fine with no problems. There sure is a better choice of brands & styles than the 265's.
Old Nov 22, 2010 | 08:39 PM
valter's Avatar
GL450
Thank you! That's great to know!
Old Nov 23, 2010 | 01:00 PM
lkchris's Avatar
'10 CL550, '12 GL550
You understand, of course, that fitting wider tires REDUCES snow traction.
Old Nov 23, 2010 | 02:37 PM
valter's Avatar
GL450
Good point! It will be a big improvement over bald tires and I hope I won't sacrifice too much of traction to get out of minivan-ish look
Old Nov 24, 2010 | 11:08 AM
Brocktoon's Avatar
GL 320cdi, Chevrolet Avalanchero, GLE 350 (on order)
Peeps in your 'hood must have some bad minivans, because 265 60 18 is a pretty big tire!
Old Nov 24, 2010 | 11:38 AM
vntgspd's Avatar
Porsche 911
Funny!
Kind of depends on the tire. The original Continentals look wimpy but the new tires on my GL in the same 265/60/18 size are more squared off and the tread width is a bit wider so they look much better - for 18's anyway.
Old Nov 24, 2010 | 12:01 PM
valter's Avatar
GL450
They are all silver Honda Odysseys, all of them... 265 60 18 is still mighty big and heavy, that's for sure
Old Nov 24, 2010 | 12:42 PM
reddog's Avatar
'03 CL500,& '18 GLS63. Gone: '83 500SEC,'99 500SL,'07GL450
I replaced the original Continental 265/60/18 on my 2007 GL450 with Michelin Latitude Tour HP 275/60/18 tires. No clearance problems even when using tire chains on the rear tires last winter in the back country. Load rating is 111H vs. 110H for the 265/60/18. Max load per tire is 2403lbs. vs 2337lbs. for the 265/60/18. Tire weight is 39lbs. for the 275/60/18 and 37lbs. for the 265/60/18.
