Mechanical key won't lock/unlock, outside handle unlocks door
Just to be clear, you can physically lock the door, yet pulling the handle will cause it to unlock?
Well, I must say, that sounds like a REALLY strange issue. I mean, how does a door opening mechanism 'break' and allow the door to open? Or maybe it's some kind of fancy-schmancy, German engineering, failsafe thing?
you have to turn the key and pull the handle at the same time or a couple of times in a certain sequence
at least on my 2008 it is not unlock and then you pull handle and it opens, it is weird
cannot remember exactly how to do it but if you can open the car now and read your manual it should give you the sequence
maybe it is turn the key the same time you pull the handle....
so i am wondering if maybe you left it in the unlock position with the manual key and it needs to be put back in the lock position.....
hope this helps, but definitely read the owners manual and find that sequence
if you dont have a manual post back and i will look it up tonite
had a battery die on my 2008 and found this out the hard way
for anyone who has not had their truck die etc had to use the mechanical key i recommend reading the manual because the mechanical key opening stuff does not work just normally
if you have not had this happen you wont know what he is talking about
I put the FOB out of range, but not too far as I read that I would need it to turn off the alarm, since entering the vehicle with only the metal key will sound the alarm. Either you stick the FOB in the ignition, or in this case (since me FOB actually works), I just retrieved it and pressed the unlock button on the FOB.
So... to get into the car was actually pretty easy (and it is outlined in the manual as Clvincent stated). I put the metal key in, then turned it CCW 90* (it wouldn't go any other direction, anyways). Then I pulled the handle once to unlock, then a second time to open. That was it.
I didn't do the lock procedure, but I saw that it requires having both driver's and driver's side rear doors open. Then reach from behind and manually lock the driver's door and close it. Then manually lock the rear door and close it.
Last Summer, at our cabin on the coast of Maine (miles away from just about anything), my wife brought the GL back from getting groceries. I was waiting to go get some more wood to rebuild one of the docks. When she came home, I hoped in the truck (never shut it off) and took off. About 40 minutes later, I pulled into the parking lot of Lowe's and reached down to turn off the engine by pushing the start/stop button. My finger got about 1" from the button and I paused... realizing I didn't have the key FOB. My wife still had it! I drove all the way to Lowe's without a key and there wasn't one single "alert" or message on the dash information screen! I ended up just leaving the truck running in the parking lot, but if I had actually pushed the button, that would have been a major PIA!!!
Very glad you caught it before you shut the truck off
Surprised there were no warnings
Do you think it is possible to leave the door handle manually in the unlock position using the metal key?
The unlock/open deal with the metal key is stupid, i do not understand why mercedes had to make that complicated
When needing to use the metal key you are locked out with the owners manual is inside the car and the unlocking and opening the door is not intuitive
It is not that the metal key does not work you just have to do it in some kind of sequence/pull it twice like dennis said and i think you have to pull the handle quickly or something, only mercedes could make this complicated lol
With the metal key, I can not pull it out in the "turned/opened" position. In order to remove the key, I have to turn it back to the starting position - at least it's that way on my '08, anyways.
rochab sounds like you cannot pull the key out in the open position according to dennis, maybe something broke when you were trying to get it open...
is it still under warranty?
if it just needs a door handle those are pretty easy to replace
Jeff
EDIT: Jeff, thanks for the PM!
Rochab... sorry for the slight hijack!
