2009 GL550 Popping noise when reversing and turning
Old Feb 25, 2017 | 08:42 PM
timwalker69's Avatar
2010 S550; 2009 GL550
Hi all, noticed a popping noise when reversing from grarage and turning wheels to the right while reversing. It has started doing it more often. Nothing to the right. I also noticed today (my wife drives it 99% of the time) that sometimes going over a speed bump in a parking lot that there is sometimes a pop also. Any ideas out there? We have replaced front right and left Airmatic struts.
Old Feb 25, 2017 | 09:32 PM
alx's Avatar
alx
Popping suggests ball joints or cv joints.
Old Feb 25, 2017 | 10:21 PM
gl450x164's Avatar
gl450 530i
Cv axels
Old Feb 26, 2017 | 12:09 PM
alx's Avatar
alx
Originally Posted by gl450x164
Cv axels
normally i would first check ball joints since they are fairly easy to diagnose. if those are tight i will wait until the cv joint wear is sufficient to be heard (pop-pop-pop) when making a slow speed full lock turn left or right
Old Feb 26, 2017 | 07:41 PM
eric_in_sd's Avatar
2007 GL450
What would be popping in a ball joint?!?
Old Feb 28, 2017 | 08:01 PM
So is there an immediate concern for safety with this issue or is it fairly safe to drive for a while? Any idea on costs to repair any of the above at a non MB repair shop?
Old Feb 28, 2017 | 08:13 PM
ItalianJoe1's Avatar
2003 CL 600
When the boots fail and they dry out, the motion of metal on metal and taking up the slack in the joint causes a pronounced 'pop' when turning/shifting weight, as OP describes, like backing out and turning. A repeated, cyclic ticking would be an axle, but one sharp pop or irregular pops, or when going straight or turning when stationary, usually a suspension ball joint failure.
Impossible to make that call over the internet. Any suspension fault has the potential to be very serious, if the joint fails completely the wheel may collapse into the wheel well and cause an accident and severe damage. That being said, there are other noise sources like bushings that can be largely ignored forever as long as you don't care about the way the car drives or sounds. You need to confirm the source of the noise and then make that decision.
Old Feb 28, 2017 | 08:19 PM
Thanks all. I just recently made a connection on something. The front wheels are always susceptible to brake dust, but more recently there has been a heavy accumulation of something more than brake dust, so can I assume that the boots have failed and this is grease being thrown out? At least it is still happening.
Old Mar 1, 2017 | 02:20 PM
eric_in_sd's Avatar
2007 GL450
CV joint grease is heavy sticky dirty blobs.
If you aren't up for jacking it up and poking around, I'd get it over to a shop and put on a pair of Depends when you get home and wait for the phone call.
Old Mar 1, 2017 | 04:47 PM
So I didn't take the wheels off, but I turned them sharply and looked behind the wheel. I could not see any of the rubber boots cracked anywhere nor could i discern any loose bolts or nuts. All looked the same on both sides. I want to rephrase, your honor, my statement about the dust on the wheel. I t is a heavy dark dust but is not grease. I can easily wipe it off with my finger or a towel, but it is more dense than the normal brake dust that i see on the back wheels. As an FYI, we did have the front airmatic system replaced in the past six months if that helps with any assessment. It is scheduled for the shop first thing in the morning. I wll post outcome as well.
Old Mar 3, 2017 | 11:59 AM
alx's Avatar
alx
this means nothing... you can have a failed joint without any damage to the protective rubber boot
the suspension needs to be unloaded and checked with prybars.
