'09 GL320 - Expired and Retired
Purchased the '09 GL320 Bluetec new - hoped to get good fuel economy, reasonable maintenance costs, and more than 200K service life. Well - got one out of three.
Vehicle now has 179K miles and the power plant is at end of useful life - engine is consuming lots of oil (1qt per tank of fuel), fuel injector seals are leaking, timing chain has stretched, check engine light on most of time, and sometimes goes into limp home mode. Car was maintained by the book - with regular services done at an MB dealer. From what I have been able to research, the engine is not rebuildable (parts not offered by MB), a new complete engine is $17K to $23K plus installation, good low mile used OM642 engines are getting rare and run $10K+, short block plus reman turbo plus fuel injectors is $10K to $12K. None makes a lot of sense to install in what would be a $10K to $12K market value vehicle when all done.
Consensus from "experts" is that the engine is "sludged up" - probably because of high miles driven (80K+) in the first 3 years before MB reformulated the oil for Bluetecs and because the oil was not changed every 5K miles instead of the recommended 10K miles. Take it or leave it for what it's worth. Also consensus is that 2nd generation Bluetecs are better - if you change the oil at 2X the recommended frequency.
So, in my humble opinion, the legendary durability of Mercedes diesels is just that - a legend - at least as far as the new "clean" diesels are concerned.
Rest of vehicle is nearly perfect.
Things I've had to do over the years: replace oil cooler gaskets and rebuild intake motors - $3500, replace AdBlue heater - $1000, replace rear air springs - $700, 4 sets of tires - $5000. Replace keyless door locks 5 times - $3000. All in addition to regular maintenance.
But - the good - vehicle has probably averaged about 27 MPG over life.
So it's time to retire the car. Will advertise as a "mechanics special" for short money - if there are no takers, will go to recycler, or donate to charity (perhaps one I DON"T like!).
Eric
For those that are interested:
http://www.ebay.com/itm/263195232549...84.m1558.l2649
A high mileage diesel with serious problems. If you could get $5k for it, you should sell it and run away. Fixing it will eclipse the value of the car by a long way. even if you are a DIYer, it still may be too expensive to repair when you consider the value of the car.
Wow... now when I looked at them those things are practically free if you can wrench yourself...
There are many ways to get rid of a vehicle, and auctioning is one of the popular ones. I'm just talking from experience, same principal can be applied to any.
, will go to recycler, or donate to charity (perhaps one I DON"T like!).Wow... now when I looked at them those things are practically free if you can wrench yourself...
It is amazing how cheap these things have gotten. We're probably just going to drive ours into the ground since we still like it and it isn't worth much to sell/trade.
Dependability of the GL diesel is very suspect as you can read with all apparent issues posted on the forum. I'm still surprised it holds any additional value than the gasser but I will chalk that up to rarity. A GL diesel gets significantly better mileage so that has some value. The gap is narrow and may soon be worth less across the board. KBB has it as less according to a member and another says the diesel still carries a slightly better auction price.
