Creaking noise from wheel during high acceleration, CV joint or something else?
Subscribe
Nov 28, 2017 | 07:35 PM
HI All
I am having a loud slipping noise on my 2008 GL320 CDI with 146,000 miles.
The issue:
While under medium to high acceleration at around 2,000 RPM and usually when coming from a stop or low speeds of about 15mph there is a loud slipping noise coming from the driver side wheel underneath the car. It will creak 2 or 3 times pretty loudly *clack clack clack* just like that. Then the noise will disappear and never be heard again at high speeds.
This noise began seemingly after I replaced the front air bags. So, I went back in there today and made sure the CV joint is pressed into the transmission and a clicking nose was heard when it was pressed all the way in. I suspected this might be the culprit because the car now pulls to the left very very slightly. Made sure all nuts are super tight and that there is no lateral movement of the air bag strut.
Suspecting the CV joint might be bad I rant the following tests:
Hit the cv joint both around the inner joint and outer joint with a rubber mullet. Both seem tight.
Drove the car in circles from a stand still with steering wheel all the way to the left and all the way to the right. No noise can be heard.
Took the car to a local mechanic who has limited experience working with Mercedes cars, he suggested the issue might be the CV joint. But he is not sure. Quoted 850 to replace.
The CV joint is only about 150 bucks. So I could replace that just to throw parts at it but it very strange that my tests did not duplicate the same noise.
So I am hoping someone can give me some pointers on how I can trouble shoot this myself.
Thanks!
Reply 0
Nov 28, 2017 | 10:04 PM
How did you secure the truck when replacing the bags? Did you put jack stands on the black metal brackets with oval shape (one on each side) that are right behind the wheels (at 3 o’clock if you are looking at the wheel from th side?) if you did- you bent them and they are touching the frame making this exact sound. If those brackets are nice and straight it is your cv joint. At 140k it is right about time for the driver side (longer cv joint prone to failure )
Reply 1
Nov 28, 2017 | 11:43 PM
Thanks for the response I guess the cv joint being bad is very plausible then.
I put jack stands on the plastic jack points under the side view mirrors.
they seem fine?
Reply 0
Dec 3, 2017 | 09:47 PM
Replaced the drivers CV joint today. Noise still persists.
what would be the next logical part to look at?
Reply 0
Dec 3, 2017 | 10:22 PM
Im gonna answer my own question
the video below shows another case of exactly the same issue
the issue ended up being the chain guide in the transfer case. requiring a new front differential.
here is a thread that was made about it explaining the situation
http://www.benzworld.org/forums/x164...e-my-axle.html
new differential is about 600 used on ebay.
Reply 0
Mar 4, 2025 | 11:29 AM
The issue:
The CV joint is only about 150 bucks. So I could replace that just to throw parts at it but it very strange that my tests did not duplicate the same noise. If writing essays feels like a never-ending challenge, there’s a simple way to get high-quality academic work without the hassle https://99papers.com/en/ offers professional writing services where experienced writers craft plagiarism-free, well-researched essays tailored to your specific requirements. Whether you’re struggling with research, formatting, or time management, their service ensures that you get a high-quality paper delivered on time, making it easier to focus on other important academic tasks while still achieving great results.
Thanks!
thanks for info!
Reply 0
Mar 4, 2025 | 11:35 AM
I has something very similar not long ago. We HUNTED for the click. Threw parts at the freaking car.....it was a cracked rim.
Reply 0
Mar 4, 2025 | 03:57 PM
As Opie said they solved it, but I read that and I heard slipping transfer case chain as well.
Reply 0
Explore
Subscribe
Currently Active Users (1)
