08 gl450 airmatic valve block clicking
before this clicking started... we had massive rain, stuck going through puddles, got home and heard the famous "psst" noise the airmatic compressor makes after getting out of vehicle, sounded different, blew out black water, removed fender liner and saw compressor intake tube once again broken from rubbing on fender liner, think it sucked in water, however with that and leaking rear air bags the compressor was shot, very noisy afterwards...
what's been done since compressor failed, front struts are a couple months old, bought new rear air bags, compressor and valve block, replaced all, put new tires on and it was perfect, drove around and not one problem, no codes were stored, all values, ride heights, and voltages read fine. a day later, battery was dead, bought new battery, reset everything and all seemed well after drive, going out to garage later i heard the clicking noise, blew it off till next day, still heard noise the next day, started it up, barely started, battery very low, charged it first night and did not charge up completely, on 12v 2amp, so decided to unplug the valve block, charged up fine and no battery drain, bought another new airmatic valve block and tried that, still same clicking noise, i removed drivers carpet and cover to airmatic computer and found nothing except a little water on the very bottom floor board, the computer sits up about 3 inches from bottom, also did notice water on passenger side floor board as well when i replaced the battery, didn't seem like enough water to cause problems but may have, water has been sucked out and completely dried, drain plugs removed to double check. airmatic computer looks water tight around unit and plugs. when i unplugged the airmatic computer plugs the clicking went away, plugged in and it clicks, cycling. there is nothing anywhere on this that i have found, any suggestions? sounds like the airmatic computer maybe? no blown fuses anywhere.
To add to my woes, the tailgate now also clicks to open but moves slights and stops. The motors sounds like it is running, just doesn't lift the gate.
Anybody with suggestions??
You might have a bad switch on a door latch. Don’t have any specific experience but see if your interior lights are playing up too
any warning messages
