Widest Tire?
Old Jan 29, 2020 | 12:05 PM
zerochills's Avatar
GL350
Widest Tire?
So, it's time for new tires (again!!!). Looking to see if anybody knows what the widest tire I can put on 20" wheels with stock suspension set up. Not looking to accomplish much more than maybe increasing contact patch. Just thought I would consider it, now that I'm in the market for tires...
2011 GL350
Old Jan 31, 2020 | 02:52 PM
reesepcpatel14's Avatar
GLK
im on 22in x 12 wheels and run 305/45/22 they rub a hair in the front but only when im on full lock
Old Jan 31, 2020 | 03:30 PM
DennisG01's Avatar
'08 GL 320 CDI
How much room do you have between the front tires and various parts of the car/suspension? Turn the wheels lock to lock and measure. Once you know that, it won't be too hard to figure it out based on tire sizes where 1" wider would roughly equal being 1/2" closer.
Old Jan 31, 2020 | 06:32 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
If you run a lower profile tire, it will not rub at all. A 45/22 is taller than the stock tires.
Old Feb 2, 2020 | 10:44 PM
not2fast's Avatar
In the market
What wheels are you running? Stock width and offset?
Old Feb 3, 2020 | 11:07 AM
BlownV8's Avatar
305/40/22 but 305/35/22 would be the correct size but they are very expensive in comparison.
Old Feb 3, 2020 | 12:41 PM
not2fast's Avatar
In the market
I was asking the original poster.
Old Feb 3, 2020 | 12:44 PM
zerochills's Avatar
GL350
Yes stock wheels. 20x8.5
Old Feb 3, 2020 | 01:38 PM
DennisG01's Avatar
'08 GL 320 CDI
What did you find out for clearances after measuring?
Old Feb 3, 2020 | 03:05 PM
zerochills's Avatar
GL350
About 1-1/8" before tire would be hitting inside fender liner
Old Feb 3, 2020 | 03:20 PM
not2fast's Avatar
In the market
That is a pretty narrow rim.
Old Feb 3, 2020 | 03:24 PM
zerochills's Avatar
GL350
Yes it is would be. Sorry I mistyped, they are 9.5". I
Old Feb 3, 2020 | 03:38 PM
DennisG01's Avatar
'08 GL 320 CDI
Would say that that 1-1/8" is the closest/smallest clearance you would have - even if the car was bouncing over a bump? Same measurement on the front of the tire as the back of the tire? Is your current tire size 275/50R20?
