Oil leak, what am I looking at?
I discovered a small oil leak today. It's in the front of the engine, driver side, right under the plastic cover, behind the power steering reservoir (picture attached). First, I thought it was power steering fluid leaking. However, I do not think that's the case now since the fluid would have to travel up the engine block. Plus, the color and smell are similar to the engine oil and not power steering fluid.
Where is it coming from then? I suspect it's leaking from under sensors 1, 2, and/or 3. Sensors 1 and 2 are attached by 1 bolt only, sensor 3 is attached by 3 bolts. Can you tell me what these sensors are and whether there are O-rings inside that I can replace? I suspect it's actually sensors 1 and 2 that are leaking, since I see puddles and gunk bellow each one of them.
It's rather tricky getting those Magnets off on the driver side without removing the power steering reservoir, but it IS possible by loosening the reservoir without completely removing it and using a 1/4 wrench to remove the bolts (be VERY careful not to strip the bolts; the passenger side is much easier.). Search the forum for a DIY.
BTW, are these sensors and magnets maintenance items? Once I remove them, shall I just replace the o-rings, or sensors and magnets as well? My truck as 11 year old now with 85K miles.
tl;dr ps procedure is:
Suck fluid out of ps reservoir
remove c-clip
undo torx bolts
remove reservoir
remove and replace o ring
seat reservoir
carefully tighten torx bolts
install c-clip
refill ps fluid
BTW, the PS o-ring you mention, is it on the reservoir side, pump side, both?
https://blog.fcpeuro.com/how-to-repl...e350-c300-m272
https://blog.fcpeuro.com/the-definit...d-m273-engines
