Shuddering: Transfer case? Torque Converter?
I've replaced the spark plugs (atrocious)
I've replaced the transfer case fluid (dirty and burnt smelling)
I'm hoping it's not the torque converter or tranny going up on me.
I'm going to do a tranny service to see if that helps. Just wanted to know if anyone else has experienced this and was able to resolve it on the cheap. If not I'll drive it to the wheels fall off, or the transmission falls out whichever happens first.
I tend to find the shudder at low rpms either before or after a shift and more intense going uphill. It's hard to tell but it's definitely at a shift point.
I never tried a tight circle full lock to validate the shudder, I will do that this evening and report back.
Thank you.
Thanks for the insight!
QUOTE=Tpr211;8142739]i had same problem, wasted a lot
of time and money chasing the problem, finally found a used transmission with torque converter for $800 and that was it, that transmision lasted another 125k+\-. i tried the transmission service, new fluid, filter, drive shaft with center bearing, probably more that i forgot, it's been a few years. but the shuttering on acceleration, mine was mostly around 3-4th gear, i think. worst this is, no diagnostic codes or test for the problem. there was a video by shop in california the first identified issue and explained it, most of all they suggested only use a MB torque converter. good luck.[/QUOTE]
last note, if you find a salvaged transmission complete like I did cheap, it’s a fairly simple repair, just be careful switching your controller plate over to the new one. The shutting will start to really annoy the more you drive.
It’s surprisingly not that hard to repair these things yourself in the driveway, I eventually replaced all struts with Arrnotts, so they’re lifetime now, oil seals, swirl motor, keep resistors around for an emergency, Keep eye out for an alternator, it will eventually go.
On this car, does the radiator also serve as transmission cooler? Maybe they put in more transmission fluid.
