Expected Fuel Pressure at the Rail
Now I am getting a check engine with lean codes. I checked the fuel pressure and am at 35lbs. Should it be higher? like 50lbs?
Did you also change the filter? It includes the regulator I believe on that setup.
It's very possible you have a weak check valve/regulator, and the new pump is strong enough to overcome it but not going to reach the right pressure. Does your pressure hold with the engine off?
Also, which engine do you have?
Thanks I ordered both. I went with MB Brand parts instead of rockauto parts this time. Just waiting for them to show up.
The 35psi sounds too low.
Are you saying that you now have 45psi on the fuel rail?
Also, yes there definitely IS a difference between the fuel pump which is on the passenger side under the 2nd row seats, and the filter/sender unit which is under the 2nd row seat on the driver side.
BTW-Not sure if this helps, but the pump that you see in the pic above providing 57psi was purchased on Amazon. It's not a Genuine Mercedes unit. I think it was the cheapest generic one I saw at the time. Cost roughly $65+S&H as I recall.
The first one was an $82 one from Rockauto. I bought cheap fuel sender from Amazon for $55. I bought MB branded ones the first time, but didn't put in the fuel sender when I saw the pressure go up a ton with just putting in the pump. I hope I don't have to drop the tank again to put in the MB fuel sender.
https://www.rockauto.com/en/moreinfo...t=10147&jsn=11
I'm sure you don't want to replace that filter/sender unit but it sounds like you might need to. FWIW-I accessed my Fuel Pump thru the interior. It was a PITA too. Not sure which would be worse, dropping the tank or going thru the top. Sorry!
It is not the most enjoyable job, but with a quick jack and a pair of 5-gallon buckets for holding things, it was not bad.
Glad to hear it sounds like your problem is resolved!
To avoid that I would also recommend getting a fuel pressure reading before putting the exhaust/driveshaft back in. It sounds pretty mean without the exhaust
on it.
