Troubleshooting Help Wanted(Needed)
Old Jul 9, 2024 | 06:37 PM
DillonGL450's Avatar
2007 GL450
Unhappy Troubleshooting Help Wanted(Needed)
Folks, I am struggling.
Backstory, purchased an 07 gl450 with a bad engine. Purchased a replacement engine and did some preping/maintenance stuff there. Got it put back in enough to where I wanted to try and turn the engine over. New batteries, radiator not installed in car yet. Turn the key, nothing happens in any position. Fuel pump doesn't kick on, starter does not turn or click.
Next, I jumped the pins to confirm the starter functions. It does. Next, I jumped the pins for the fuel pump to confirm it functions. It does.
Next, I pull codes to begin to try and understand next steps.(youcanic scanner, Like it so far.)
Codes:
ME9.7:
P2176- Preeform throttle valve adaptation
P0607- voltage supply of component motor electronics/battery voltage too low for ADC
P2505- The voltage at relay circuit 87 is too low
No CAN signal from control unit traction systems
P2158-implausible CAN signal from vehicle speed at front axle
P0102- open circuit/short circuit to ground or to positive
P0101- MAF sensor is too high
EIS:
Pass, no faults.
Then, based on what I could find on the internet in regard to the above information along with the symptoms I had. I decided to send out my ecu and have it repaired. They deemed it a non economical repair. So I purchased an ECU, EIS, and matching Key set from a 2010 GL450.
Today, with these items swapped over. I was able to recreate all of my symptoms and pull codes again. I know the vin is coded to the ecu and EIS, but figure that if I use a matching set all should be well? Perhaps the model year difference is enough to cause its own problems.
Codes:
ME9.7
No CAN message was received from control unit traction systems
P2158
P2176
P0607
P2505
EIS:
Undervoltage supply
Terminal 30 NOT PRESENT
Okay, with all that said. Anyone have some experience with issues such as those above. Any insight would be great.
Thanks,
Old Jul 9, 2024 | 08:06 PM
vesiadog's Avatar
1998 SL500,2011 GL550,2009 ML350,past 1995 E320 Cabrio ,2005 ML500,2006 ML500,1996 SL500,1972 280SEL
engine swap
Codes:
ME9.7:
EIS:
Pass, no faults.
Codes:
ME9.7
P2158
P2176
P0607
P2505
EIS:
Undervoltage supply
Thanks,
The best advice I can give is to get on every MB forum W164 and X164 and search help on engine/electronic swap and hope you find individuals with experience… they do exist . Definitely not an easy road … good luck!
Old Jul 10, 2024 | 06:31 AM
GL500 x164's Avatar
GL500 x164
Ground strap?
Edit: P0102- open circuit/short circuit to ground or to positive
Just a guess because they are so random and systems really unrelated to each other.
Either that or an electrical plug is in the wrong connector or not connected?
Old Jul 10, 2024 | 09:52 PM
Zodwraith's Avatar
2008 GL450
Takes a brave soul to attempt anything as big as an engine swap in any relatively modern MB. Anyone else miss the days they just made good cars instead of rolling computers with security paranoia?
Old Jul 10, 2024 | 11:15 PM
Max Blast's Avatar
NGL450 w/EORP, S550
I’d recommmend that for a project of this magnitude you ditch the you can scanner and get a proper MBStar compatible system.
You’ll be programming VINs and doing off-line coding on a number of control units to make it all talk together.
That’s completely aside from the possibility that one or more of them aren’t plugged in or have bad grounds, as evidenced by some of the codes you’ve pulled up. That is a lot of work for an 07.
Old Feb 11, 2025 | 06:11 PM
2007 GL450
Wow, its hard to believe I spent this much time and effort troubleshooting this project. Eh, I learned a thing or two. Plenty still to do on the rig, but got to drive it for the first time today.
Officially 5.5L swapped the 07 GL450, bbspoolside's question on if this was possible and ultimately preforming this swap a few years ago led me to purchase a 5.5L off ebay as they were at the time slightly cheaper and more available.
Big lessons learned on my end: Identical part numbers, turns out the bulk of my issues were from not just using the wire harness from the GL in the first place. I looked over the SL550 wire harness and made a couple minor modifications and tried to save myself what amounts to about an hour of work swapping the harness over while I had it on the bench. Subsequently convinced myself it can't be the harness, there must be some issue with the wiring. Hours. Hours of time spent with wiring diagrams and my multimeter, and scratching my head raw. Finally, I just swapped the harness. Naturally it worked, after getting the fuel rail primed.
Old Feb 11, 2025 | 06:15 PM
vesiadog's Avatar
great writeup
Thanks for sharing … this can save a future swap a lot of time!
Old Feb 11, 2025 | 06:30 PM
2007 GL450
https://mbworld.org/forums/gl-class-...gine-swap.html
I don't know if the link above will work or not, but this links to a thread with some other good information. End of the day, this swap should feel like a plug and play swap if done correctly.
Old Feb 11, 2025 | 10:37 PM
Max Blast's Avatar
NGL450 w/EORP, S550
Nice.
If you’re then reusing the 450 Ecu you would need to go into das developer mode to tell it the base engine is a 5.5 l, I.e switch the base engine from a 4.7l to 5.5 - otherwise I think it might just limit output to 330 hp out of what is capable of 380 hp.
Old Feb 12, 2025 | 12:40 AM
GL500 x164's Avatar
GL500 x164
I've been on message boards for years. You are one of the very few people who comes back the give the story an ending. Legend!
I lol'd because what you wroted really conveyed your level of frustration. Sucks, but glad you sorted it in the end. Well done.
Old Feb 12, 2025 | 05:58 AM
2007 GL450
Originally Posted by Max Blast
Nice.
hmm, Interesting. Probably so, I will be looking into developer mode it seems. Thanks for the note, would hate to not have the hp bump at this point lol.
Old Feb 12, 2025 | 06:55 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Originally Posted by Zodwraith
security paranoia?
Who told you that? Wait, did they tell you? When? Hold on, what all did they tell you? Something is wrong here......
