Tire blown, opinions needed
Old Aug 29, 2014 | 07:28 PM
Cybervlad's Avatar
GL550
Well it was bound to happen one of these days, so why not today...
Wife hits a major pothole, blows out a tire on a 2014 GL550. Tire can't be repaired and needs to be replaced.
We have 9000 miles on the car and all 3 remaining tires are 8/32 tread left vs 10/32 new. Went to the dealership, they tell me to replace all 4 (duh) because they need to be absolutely same which is just ridiculous.
Do you guys think I will be fine with just installing a new tire and having a 2/32 difference in tread?
Or should I go through the trouble of shaving a new tire off down to 8/32 to match other 3?
How sensitive is the GL AWD system to a 2/32 difference in tread depth?
Thanks in advance for any educated opinions.
Old Aug 29, 2014 | 09:42 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
I would imagine you will be fine.
Old Aug 29, 2014 | 10:18 PM
JimBarnhart's Avatar
2015 Ram 2500, former 2013 GL350, 2007 GL450
I tend to agree with BlownV8, you should be fine. At absolute worse case you could buy two and match fronts and backs.
Old Aug 29, 2014 | 10:26 PM
fabbrisd1's Avatar
A gaggle of MB's
The fact is 9000 miles is 9000 miles - and you list a GL550 - I congratulate on the conservative driving - but frankly the last 25%-30% of tread is going to get a bit harsh feeling for a GL550.
If it was me - I would quote 2 replacements from Tirerack -with Road Hazard - then challenge the dealer to match - install on front - then have a match 9K pair on the rear - with one 9K tire in your garage as a spare...
Old Aug 29, 2014 | 11:51 PM
cookstar's Avatar
2005 ML350, 2008 GL320, 2013 Gl350
I would never in a million years replace just one tire after 9000 miles, dont be cheap on things like this, get all 4 replaced, even if the other 3 are safe (which I doubt) you will at least have 100% peace of mind. Get a couple quotes than ask MB to price match. Get the rim and tire warranty next time. Its a relative bargain given the replacement cost of tires/rims.
Old Sep 1, 2014 | 10:09 AM
Mbenz260e's Avatar
2022 E450 Prior:2021 S580 2012 E350BT, 2013 GL350BT, 2009 ML320BT, 2006 E320CDI, 1987 260E
I would agree with this approach as well, did something similar on my W212 last year.
Old Sep 2, 2014 | 08:54 AM
Cybervlad's Avatar
GL550
I ended up getting a tire shaved down to match the other 3 off tirerack. Getting installed tomorrow.
Seems like the most cost efficient approach.
thanks everyone for their input!! This forum is very helpful as always.
Old Sep 20, 2014 | 06:30 PM
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Give all that we know about tire wear on our GL's ..... I agree with the above!
