NEW 2016 GL 450
Old Feb 11, 2016 | 04:31 PM
hellzprince1's Avatar
ML 350
NEW 2016 GL 450
got this with the rear seat entertainment, hot/cold cup holder, parktronic with active assist, appearance pkg, beige interior, keyless go, p1 pkg. it is a lease. i hate the wheels. I want to change them to 22s. Any recs? also want to paint calipers to amg red, but its a lease, so would they charge me when I hand it over at the end? its only paint and im not changing the calipers themselves. any thoughts and advice would be appreciated for this newbie.
Thx
Old Feb 11, 2016 | 07:23 PM
fabbrisd1's Avatar
A gaggle of MB's
Sure .... if it's a lease .. don't do any mods that can't be "reversed" back to stock..
Old Feb 11, 2016 | 07:27 PM
ML 350
anyway to get the paint taken off of the calipers
in 2.5 to three years?
Old Feb 11, 2016 | 10:59 PM
vdubpower's Avatar
i drive them all, fast and hard
plastidip?
Old Feb 11, 2016 | 11:34 PM
Mike450's Avatar
2015 gl450
Caliper temps can easily approach 200+ degrees. Whatever you plan on using, keep that in mind.
Old Feb 12, 2016 | 02:12 AM
GL-'s Avatar
GL-
2016 GL450
On the positive side, if you don't use high-temp paint, the red paint should remove itself before the end of the lease.
Old Feb 12, 2016 | 04:16 PM
anothercar's Avatar
2002 C4 Cab, 2014 Audi A5 cab, 2017 X5 35d
22" wheels will change the driving characteristics of the vehicle. I'd think twice before I did that on a lease!
Old Feb 12, 2016 | 05:21 PM
ML 350
Yea the car is for the wife but i really hate the wheels. She likes the soft ride especially with the baby. What if I went with 21s instead? How much of a difference would that make compared to the ones I have currently? I would not put low profiles on them.
Old Feb 12, 2016 | 05:41 PM
Zeyad Alkaisi's Avatar
I love my 2016 gl350
Check with a dealer, I was told to never do that.
The cars gears are correlated with the wheels.
Old Feb 12, 2016 | 06:41 PM
Mike450's Avatar
2015 gl450
Here's an idea, get aftermarket 20" wheels that you like, swap the OEM tires to them, and put a set of Blizak snow tires on the OEM wheels.
You'll drive 9 months a year with wheels you like and at end of lease, swap tires and sell your aftermarket set as a winter set to another buyer.
Of course, assuming you live in a snow state, cause if you do, the OEM Pirelli 20" tires are horrid in as much as a dusting of snow.
Old Feb 12, 2016 | 06:48 PM
cadetdrivr's Avatar
2014 GL350
The underlaying issue is the outside diameter of the wheel/tire combination for proper speed and odometer measurements as well as clearance. In reference to the gear issue, there is a potentially a big problem on all-wheel-drive vehicles if different sizes are used on the front and rear axels if the vehicle is not designed for it.
Notice that MB uses different tires with each OEM diameter wheel to keep the total size approximately constant.
I'm not sure offhand if this is possible with a 22" rim on a GL.
Old Feb 13, 2016 | 01:02 AM
ML 350
Yea im in TX. No snow here. I probably wouldnt get the staggered look. I also want to get quality wheels. Something that wont get messed up easily.
Old Feb 13, 2016 | 11:28 AM
Mike450's Avatar
2015 gl450
20" or 21" would work fine for the truck. You can play with the tire size and wheel offset also to get the look you want.
If you care about the wheel resale value after the lease, I wouldn't go larger than that.
