GL450 shift lever stuck in park
Old Jan 11, 2019 | 11:38 PM
Fatarse's Avatar
2013 GL450
Having problems moving our 2013 GL when using the push button. Sometimes it goes into gear, but other times it will just stay in park (won't engage drive or reverse). Just bought a new push button yesterday, but same intermittent problems. Using the key, the vehicle will always go into drive/reverse...any thoughts?
Old Jan 12, 2019 | 01:31 AM
fabbrisd1's Avatar
A gaggle of MB's
Keyless button turns engine on - then with engine on you can shift gears - so is the issue actually non-start ?
Old Jan 12, 2019 | 10:10 AM
Fatarse's Avatar
2013 GL450
Keyless push button will start the engine, and sometimes shift into gear, but sometimes just stays in park. When it's stuck in park, I turn the engine off, then restart the engine with the key in the ignition to get it to shift into gear. It always works with the key, but has had intermittent success with the push button.
Old Jan 12, 2019 | 11:46 AM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
how is your battery voltage?
It might be your auxiliary battery
Have you ever replaced either?
Old Jan 12, 2019 | 01:42 PM
Fatarse's Avatar
2013 GL450
Not sure about the auxiliary battery, but main battery was replaced in fall of 2017. I'll ask the shop to test when we take it in next week
Old Jan 12, 2019 | 02:18 PM
Tirgoman's Avatar
2023 AMG EQE 53
Could be the brake light switch, car won't go into gear unless it's pushed. On a previous C300 my wife had if it sat for while the brake booster lost vacuum and she would have to push real hard on the brake peddle to depress it enough so that the brake light switch was activated. This was random unless we figured it out, and on a basically brand new car. They adjusted the brake light switch to fix the issue.
Old Jan 12, 2019 | 02:19 PM
kombifan's Avatar
How handy are you?
It's not worth the diagnosis fee
Amazon Amazon
Old Feb 24, 2019 | 05:15 PM
kvn's Avatar
kvn
2016 GL450
Did you ever find out the gear shifting issue? If you don’t mind to share how you resolved it. My brother ML350 just have the same issue like you described.
Old Feb 24, 2019 | 05:47 PM
Fatarse's Avatar
2013 GL450
Main battery is testing low, so I'm waiting to replace both batteries to see if that does the trick.
Old Mar 7, 2019 | 07:32 PM
Fatarse's Avatar
2013 GL450
No more issues with the new battery
Old Mar 7, 2019 | 08:12 PM
kombifan's Avatar
Awesom . You replaced both?
Old Mar 7, 2019 | 08:19 PM
Fatarse's Avatar
2013 GL450
Correct. Both the main and auxiliary battery
Old Mar 7, 2019 | 08:29 PM
kvn's Avatar
kvn
2016 GL450
My brother also confirmed that after charging up the battery on his ML350, he doesn’t experience intermittent the locking issue anymore.
Old Apr 3, 2020 | 08:58 PM
angelglo's Avatar
Veteran: Marine Corps
s500 GL450 GL63 Z71XL Yukon 67 396 SS velle 68 Vert Camaro 69 RSSS Vert Camaro 75 Blazer
So, im getting the same problem also. Push button will start but will not shift and its intermittent. This usually happens the first start-up of the day. But.... when I use the key, it will start and shift into park or reverse. I did change the aux battery but I guess I have to take a look at the main battery. This seems strange to why this would happen with with the push button start and the key.
Old Apr 6, 2020 | 09:48 AM
vivaitalia's Avatar
2013 GL450
well this is coincidentally odd ... about 5 days ago, engine started with the push of button, but gear did not engage ... turned engine off waited 15 seconds and started engine again ... nothing ... shut engine off got out of car, shut the door, 15 seconds and got back in car and started engine, still couldn't engage the gears (freaking out at this point) ... shut off, out of the car, "LOCKED" the car, waited about 30 seconds, unlocked car, turned engine on, and voila, gears engaged .... so if the battery can power the starter and alternator and i'm up and running after a few tries, what could be the connection to the batteries ??? perhaps the slightest drop in voltage might have affected just the gear changing mechanism, circuitry, whatamacall it ??? I'm thinking that this will happen again for me ... hmmmm
Old Apr 8, 2020 | 05:24 PM
kvn's Avatar
kvn
2016 GL450
My brother replaced the main battery and everything is back to normal
Old Apr 16, 2020 | 05:08 PM
angelglo's Avatar
I haven't done it yet but that will be my next thing to do is replace the main battery.
Old Jun 1, 2020 | 09:38 PM
vivaitalia's Avatar
2013 GL450
Can you share details of the the two batteries you replaced? where did you get the batteries, which type of batteries? Thanks,
Old Jun 4, 2020 | 10:37 AM
Gill Senderov's Avatar
Mercedes GL450
Personally, got mine here, where your warranty will be 4 yrs instead of 3. Excellent battery & don't forget to use the 10% coupon.
https://www.batteriesplus.com/productdetails/sli49agm
https://www.batteriesplus.com/produc...ra/slaa12=1.3f
Alternatively, if you have a Sam's Club membership (you can get one online for $20-$40), but as far as I recall, they carry only the Main battery.
https://www.samsclub.com/p/auto-grou...ee/prod9510087
