Water Leak GL 550
Old Nov 5, 2019 | 08:57 AM
Andy Scott's Avatar
GL 550
Water Leak GL 550
HI
I have a water leak , which appears to be coming from a hose with crimped connections. Is it possible to replace this hose with regular tools, or is it a dealership job?
I have attached a couple of pictures. This hose is wet and swollen, so appears to be the culprit.
Old Nov 5, 2019 | 10:21 AM
Andy Scott's Avatar
GL 550
Would anyone know the part number for this hose? Thanks
Old Nov 5, 2019 | 05:15 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
That is AC hose. Could be just condensate drips from outside or something else is leaking around
Old Nov 6, 2019 | 03:13 PM
Forrest Gump 9's Avatar
shrimp boat
Look up, probably something above it leaking down
Old Nov 7, 2019 | 11:19 AM
Andy Scott's Avatar
GL 550
Turned out to be turbo coolant pipe.
Old Nov 7, 2019 | 02:52 PM
shrimp boat
How many miles? Very labor intensive job
Old Nov 8, 2019 | 11:16 AM
Turbo coolant
pipe is a common issue with M278. It is the one on top of the engine with plastic housing.
Old Nov 8, 2019 | 02:56 PM
Andy Scott's Avatar
GL 550
75,000 miles. Bit the bullet and had done at local Mercedes independent shop
Old Nov 8, 2019 | 02:57 PM
Andy Scott's Avatar
GL 550
Originally Posted by arsupisemnet
Turbo coolant
Yes, it was plastic housing which was leaking.
Old Nov 8, 2019 | 03:10 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Makes perfect sense to use plastic right next to a 1600 degree turbocharger.
Old Nov 8, 2019 | 10:02 PM
I had mine replaced at 40k miles.
