malfunction light
Anyone want to weigh in and make a WAG as what's tripping this message?
Can you get the truck to the raised position? Let it sit like that overnight and see if a bag leaks.
Out of curiosity, why did you check the voltage of the aux battery? It doesn't factor in here, at all. And... side note... did you check the battery after the car had been sitting overnight (for a more accurate test)?
@MJ50 I hate to see our poetry exercise leave X164, but right is right.
(which sounds like a cosmetic surgery issue, tbh)
shouldn’t be any codes associated with airmatic, if you interrogate the ECM you may get compressor runtime read out, which will indicate how har it has worked. That; however is no substitute for hooking your peepers on it and looking and listening for obvious malfunctions. Such as it not running when raise button is pressed. Compressor still likely culprit as bags were recently changed, it had led a hard life prior to that and even harder now that it has resistance and demand to contend with.
OP, off you go but do report back please!
We gave you pretty much all the information you need to get a good start on your problem. GL.
BobC
BobC
(An essential tool for owning one of these cars)
