GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
Resonator delete
Old Nov 18, 2019 | 09:34 PM
Aresthegod1's Avatar
GL63 AMG
Resonator delete
What would be the best way to delete the resonator on a Biturbo? X pipe H pipe or any other options you guys may know... I’m new to this turbo thing 🤷🏽*♂️ Sold my 2012 c63 for a GL63. I miss the pops and crackles.
Old Nov 19, 2019 | 11:39 PM
black06c230's Avatar
mgLipGD
The stock resonator is an H pipe setup. I removed mine and put in H pipe style.
this alone won’t really give much in terms of pops. I have catless down pipes, the above H pipe, tuned and elec exhaust cutouts. The pops and such hear with slight open of cutouts but more so with mostly or all open. Then more so when using the paddles to keep in RPMs
Old Nov 20, 2019 | 04:54 AM
Johncy2000's Avatar
2019 GLS63 AMG Diamond White
Replace the resonator with two 3" pipes. No crossover. It sounds great and not too loud.
Old Nov 22, 2019 | 02:12 PM
SGTzAMG's Avatar
Veteran: Army
02 C32 AMG, 05 SL55 AMG, 09 SL63 AMG, 14 E350, '18 G550, 92 300ZX & 15' GL63 AMG
Id love to see a video please! i have been contemplating to do the same as well with my GL63
Old Nov 22, 2019 | 04:19 PM
Johncy2000's Avatar
Here are some clips!
Old Nov 22, 2019 | 04:35 PM
Johncy2000's Avatar
Old Feb 17, 2020 | 02:02 AM
nkc's Avatar
nkc
2012 C63 Coupe P31 CF Trim - Eurocharged V7, 2012 RangeRover Autobiography, 2017 GLS 63 Amg
whats the size of ur wheel and tyres, and it seems ur lowered... how many mm ?
Old Feb 17, 2020 | 03:23 AM
Johncy2000's Avatar
Stock AMG 22”s. Lowered 33mm all around.
Old Feb 17, 2020 | 03:24 AM
nkc's Avatar
nkc
[QUOTE=Johncy2000;7982878]Stock AMG 22”s. Lowered 33mm all around.[/QUOTE
looks very nice
Old Feb 17, 2020 | 03:26 AM
nkc's Avatar
nkc
What module did u use for lowering
Old Mar 14, 2020 | 12:36 PM
opelrsx's Avatar
2019 GLS 63 AMG
Bring this up.
How much louder it can be after resonator delete than stock? Want a bit more noise on my 2019, but defenitely not too loud.
What do you guys replace the resonator with? didn't find any direct replacement pipe.
Old Apr 26, 2020 | 03:22 AM
BsbAMG's Avatar
'12 Jaguar XKR-S, '15 GL63, '18 Navigator L, 2015 E250
Originally Posted by opelrsx
Bring this up.
I would say it is a lot louder. But, it it is a low growl loud and fits the GL.
Any muffler shop will know what to do if you ask them for a resonator delete. They'll cut it out and weld in appropriate ly sized connecting pipes.
Old Apr 27, 2020 | 10:33 AM
Chedman13's Avatar
2014 Mercedes-Benz GL63 AMG
I use a supersprint mid-pipe. You have to weld it to your OEM muffler, but it's a direct fit to the downpipes. The OEM exhaust has no separate mid-pipe and it's one huge piece. So you need to cut right before the muffler and use a reducer 3" to I think 2.5 or 2.75".
It's cheaper to use a straight pipe as suggested above, but I have a Brabus rear section so no cutting was needed. Rado downpipes, supersprint mid-pipe+reducers into brabus rear section. No cutting done.
Old Apr 27, 2020 | 01:41 PM
opelrsx's Avatar
2019 GLS 63 AMG
Thanks guys! I was thinking straight pipe only, the shop I talked to said X pipe will be louder than straight. But I am still wondering how loud it will get. The 63 is my daily kids hauler so gotta be "resonable" loud =)
Old Apr 27, 2020 | 02:04 PM
Chedman13's Avatar
1) Straight pipe = loudest.
2) X pipe = second loudest.
3) H pipe = least loud.
X and H pipe the frequencies of the exhaust can collide into each other and help balance it out.
If you don't mind a loud start-up, go with straight pipe. It's really only loud when you get on it. Mine is a kid-hauler and no issues. The only issue I have is turning on the car from a cold-start, it is really loud.
Old Apr 27, 2020 | 03:41 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Don't put an xpipe on a turbocharged car. Go with H or straight.
Old Apr 29, 2020 | 03:14 AM
Johncy2000's Avatar
Straight pipe made a difference in response on my 2019.
Old Apr 29, 2020 | 02:11 PM
opelrsx's Avatar
2019 GLS 63 AMG
In a good way?
Old Apr 29, 2020 | 02:15 PM
Johncy2000's Avatar
In a good way?
yes. When I had the Xpipe on, it was about the same volume as stock. After straight piping it with 3” pipes, the car feels like it has more response and power. I highly recommend this as this is very inexpensive and does a lot for sound and response!
Old Apr 29, 2020 | 02:16 PM
Johncy2000's Avatar
Here’s a vid.
File Type: mov
Old Apr 29, 2020 | 02:34 PM
opelrsx's Avatar
2019 GLS 63 AMG
Great to know! how much louder would you rate it compare to stock?
Old Apr 29, 2020 | 02:46 PM
Johncy2000's Avatar
20% Louder
Old May 2, 2020 | 02:05 PM
opelrsx's Avatar
2019 GLS 63 AMG
20% Louder
Sweet! Thanks!
