GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
2015 GL63 AMG Massage seats not working
Old Dec 27, 2020 | 08:42 AM
GhostRider91's Avatar
GL63AMG
Exclamation 2015 GL63 AMG Massage seats not working
Hello would appreciate any help just purchased a 2015 gl63amg when I select the massage settings or any other setting it resets back to zero
ran the codes with a simple ob2 scanner got some codes
B1EA953 PUMP HAS MALFUCTION IS DEACTIVATED
B1EA998 PNENUMATIC PUMP FOR MULTICONTOUR SEAT HAS MALFUCTION THE COMPONET OR SYSTEM HAS OVERTEMPATURE (DONT MIND THE INCORRECT SPELLING)
I KNOW how to work on a chevy ford Nissan not a Benz I would like to keep this car I love it so far but
I looked into it thinking it may be the pump for the seats ???
was reading it can be manyyyyyy other problems
I would like to know where to start
can't find any info on this specific car
thank you for any help
Old Dec 28, 2020 | 09:52 AM
Richard Nummi's Avatar
09, SL550 and 14 AMG GL63
So.... funny you should mention
Same deal w mine. 2014 GL63. You get a leak in seat airline (think neoprene aquarium air pump type line)... leak causes air pump to run constantly trying to establish pressure... air pump burns out....
$450 at MB dealer to identify leak, replace air pump. According to MB, especially prone to this issue in really hot climates across southern US where interior summer temps equivalent to nuclear reactor core are common.
Old Dec 28, 2020 | 06:03 PM
GL63AMG
Thanks, do you know what air line was leaking ? I was looking into it and there are many air lines ones that run to the seat and then a maze of them in the seat
and they charged 450 to replace the pump and fix the line not bad
I called MB and they told me $1000 just for the pump they may have been speaking about the pump for air ride but they would not give me a part number, got to love them
also yes this is a Florida car with black interior so yessss nuclear temps in the summer
and additional info would be much appreciated
thank you Richard
Old Dec 29, 2020 | 06:59 AM
Well.....inre Air Line
If you were so inclined in the DIY world...
1. replace air pump.
2. listen for, try and find leak (you will probably hear it, that pump puts out a lot of psi.
3. If able to locate, replace line, if unable, unplug pump so as not to burn it out again.
4. I would also try “capping” off one seat at a time... just to ID which seat has the air leak. If pump stops, you have identified culprit for further tracing. Note that the “capping”technique is also useful for tracing each branch line. You can always plug in a airline union in each place you cut till you find it.
5. If all else fails, by capping off the main line to the offending seat, at least you have the other seat working and you won’t fry your pump.
6. This issue is endemic in MB. I get the lumbar air support, every mfg. uses air. But seat pan and side bolsters? Those should be mechanical IMO.
7. Last resort: Give up, pay the 1k get your seat fixed by the shop.
Old Dec 29, 2020 | 07:05 AM
Which air line?
Passenger seat main line right under seat....MB also had initially quoted 1k to diagnose repair. Aforementioned cap technique is exactly what they use. Seat out w/ extension line spliced in to diagnose (i.e. put their ear next to seat to listen for air escaping whistle). 😉
Old Dec 29, 2020 | 07:21 AM
Great youtube video
“Fixing the SL500 r230 multi contour seat” by MGuy
Old Dec 29, 2020 | 02:31 PM
GL63AMG
Thank you I will look into it when I have a chance I will start by replacing the pump
I'm having a problem finding the pump, they quoted me 1000 just for the pump that was over the phone hope they were talking about a different pump
I will call again today and see what they say
thanks again !!!
Old Feb 3, 2024 | 01:30 PM
Jason Stewart's Avatar
2013 GL550
thanks again !!!
@GhostRider91 curious if you resolved your seat massage and lumbar issue. If so, did you find out what the part number was?
Old Apr 18, 2024 | 10:30 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
All -
Not sure if y'all got your seats fixed...but....I did.
I ordered this kit on Amazon -
Amazon Amazon
On both front seats there are two air hoses (enclosed in a felt-ish wrapper of sorts). There is a blue and black. Both side the black hose had failed in multiple areas and was just falling apart.
The fix: use a fine point awl to pop off the fittings under the seat next to the pump, also, remove the rear cover of the seat (two lower screws, the back pulls DOWN and out). You will see the black and blue hoses go to a distribution box and another connector (blue) going under. I Used a razor blade to carefully cut the fittings off of the old hose (to reuse on the new hose). There were two zip tie mounts under the front of the seat - but the zip tie (you replace them in the tie mounts). Then, tie a string to the tubes, pull them out towards the front of the car (leaving the string).
Attach the string to a pair of the new tube (both blue) and pull them trough, decide what one is going to pretend it is the failed black tube. I put the fittings into the tube by hand and used a heat gun to shrink the ends just a tad - plug them in, cut to size it the back, replace the zip ties....put the seat back on an be done with it.
Drivers seat took me 45 minutes - passenger side took me 15 minutes.
Old Apr 18, 2024 | 02:05 PM
2013 GL550
Originally Posted by OldManAndHisCar
All -
I ordered this kit on Amazon - https://www.amazon.com/dp/B07RJ1BYKV...roduct_details
thanks for this update! In your case, what was the symptom you were trying to fix? Did you ventilated seat button stay on for a time and then turn off?
Old Apr 18, 2024 | 10:22 PM
Nothing worked....lumbar, message...well, those two did not work...
Old Oct 7, 2024 | 06:55 AM
Unclewad, my final post, that was a response to what was wrong, prior.
Happy to report everything still 100% functional. And, I have done two more seats in other cars since then. Really, a very simple process once you do it once.
Old Oct 7, 2024 | 09:53 AM
Unclewad's Avatar
2017 GLS63 - 2018 AMG GTR
Thank you OMaHC, and thanks for the repair writeup!
I ordered from your link (6mmOD blue tubing) - Attempting this next Saturday, wish me luck.
Old Oct 7, 2024 | 12:17 PM
As a note - the ONLY thing I used from the kit was the hoses and two of the press in connectors. The rest is trash. Being careful it is quite easy to re-use the connectors that are already in the seats as they are compression fit.
It was a MASSIVE help to use the current hose as a pull for the new one past the pivot of the seat, this of course is assuming the current hose is not too brittle to use as a pull.
Since my post I have done three more MB seats...feel free to PM me with questions and I would be happy to get you my phone number if you run into a snag.
Old Oct 7, 2024 | 12:33 PM
Unclewad's Avatar
I'm truly amazed at your helpfulness. Thank you so much!
Jeff
Old Oct 7, 2024 | 01:16 PM
Smile
Jeff
Dude, the hundreds of times forums have saved my rear end...we just pay it forward
Old Oct 11, 2024 | 08:07 PM
Unclewad's Avatar
Hi OMaHC,
Attacked this job this evening. So far on drivers side, got panel back off (not easy the first time) and immediately saw a black hose broken off what looks like a white filter. It's a start
Both, black and blue tubes are mildly brittle but don't look that bad. But I'm going to do what you did and just replace both. Weirdly, the other tubes connecting to the air "manifold" box seem way more supple. I'm tracing black and blue tubes to under the front of the drivers seat, is that the "air pump" that the black tube goes into? Can you hear it when it runs? Does it have it's own dedicated fuse?
Thank you,
Old Oct 24, 2024 | 12:43 AM
Unclewad's Avatar
Thank you OMaHC -
Both seats are now fully operational. Getting the 1st seat back off was a pain. Doesn’t really make sense until you get it off and see how it is fit together. (Remove the 2 screws at the bottom, then grab the seat back and pull down, wiggle it, repeat. I thought it would never come off. But it does)
Passenger side back was off in 2 minutes.
The broken air tubes were not hard to find on mine. Both the main tubes (Black and Blue) that run from the center of the back seat, around the side of the seat, and connect under the front seat cushion to the junction boxes had broken in half in multiple places. Mainly in the corner where the air tubes make a 90, right where the pivot joint of the seats are. That tube kit you linked to Amazon is perfect, I love push fittings!
Like you said, 1st seat took 45mins, 2nd seat took 15 mins.
Old Nov 13, 2024 | 05:33 PM
Funinthesun946's Avatar
Some really good info here!! have the same issue in the 2016 GL63 AMG we just purchased. nothing in the seats work driver or passenger side. Not sure yet if pump is burnt.. but at least I know where to start and what to do. Thank you!!
Old Feb 3, 2025 | 02:47 AM
timsen1's Avatar
2014 GL550
Really good info, thanks everyone. I need to do the same on my 2014 GL550.
Does anyone know if the part number for the pump is 0008005519?
Thanks!
Tim
Old Feb 3, 2025 | 07:29 AM
Thanks!
Tim
I would double and triple check that it is your pump. Costs a ton more than the tube.
Old May 24, 2025 | 09:36 AM
GSClarkGL63's Avatar
GL63 AMG, S550
Ordered hose kit
Kit ordered from Amazon and due in today. Will attempt removal of seat backs in the morning. With these instructions I feel confident and hope I don’t get frustrated with step one. Patience will pay off I’m sure.
Old Feb 2, 2026 | 05:05 AM
CDobby's Avatar
E350/ GLS AMG 63
Lightbulb
All -
This is extremely helpful. I bought a preowned 2018 GLS AMG 63 and the massage seats are working. I looked under the passenger seat and can tell that the black line in the front of the seat is cracked. I will use the hoses in your link. did you use 6mm or 4 mm?
