GLA Class (X156) Produced 2013-2020
GLA Key Fob Problems
Old Apr 9, 2022 | 02:15 PM
Graham.D's Avatar
GLA
Question GLA Key Fob Problems
My newly bought(3 weeks ago) 2018 GLA key fob keeps on disconnecting, I have changed the battery 3 times now, so it is obviously not that, has anyone got any solutions to this, thanks in advance
Old Apr 9, 2022 | 02:50 PM
W205C43PFL's Avatar
Same issue with the spare key?
Old Apr 9, 2022 | 02:57 PM
Graham.D's Avatar
GLA
Hi, thanks for reply, yes, same problem with spare fob I am afraid
Old Apr 9, 2022 | 03:00 PM
W205C43PFL's Avatar
Might be the EIS module then... That being said, you could try a different brand battery if the new batteries you tried didn't solve the issue, your key accepts CR 2025. You could also try removing possible sources of interferences. Since you just got your vehicle, it should be covered by some sort of warranty by the selling party, no?
Old Apr 9, 2022 | 03:38 PM
Graham.D's Avatar
GLA
Thanks for that, I will try a different battery, i have also got a warranty, so I will check that if 1st solution doesn't work, just a couple of queries, you mention interference's, what sort do you mean?
Old Apr 9, 2022 | 03:41 PM
Graham.D's Avatar
GLA
Sorry, posted before I finished there, so secondly what Is the EIS module? I am actually working away for next few days, so I'll not be able to tell you if I have solved this for a few days
Old Apr 9, 2022 | 03:45 PM
W205C43PFL's Avatar
Interferences such as having your key in the same pocket as your smartphone as some people report with MB's Keyless GO although it isn't always an issue.
Other interferences might be the ones in your garage, rare but certain types of garage door openers can interfere it although most modern ones don't. It is unlikely your garage door opener remote will have interferences though. If you live near a transmission line it may or may not interfere with it too.
Try removing your key from your bag or pocket and putting it in the cup holder to see if it helps it start easier.
I also seen updates to the EIS module solving issues like Keyless GO so it might be that you don't have to actually replace the hardware, this is especially true if the software version installed is a faulty one.
Old Apr 9, 2022 | 03:46 PM
W205C43PFL's Avatar
no problem, EIS stands for electronic ignition system. It is part of the hardware you plug your key in for non keyless start vehicles, communicates with the immobilizer of your vehicle. If your vehicle has Keyless GO, it is the same thing you see when you remove the push start button on your vehicle. That gives me idea, try starting the vehicle the old fashion way by removing the push button and inserting the key, turning it. If you don't have issues anymore then it is unlikely you have an hardware issue.
Old Apr 9, 2022 | 03:59 PM
Graham.D's Avatar
GLA
Ah, right, yeah, I'll keep an eye on the interference's you have mentioned, thanks for your possible solutions, I will be in touch to let you know how i get on in a few days when I get home, Graham
Old Apr 9, 2022 | 04:21 PM
W205C43PFL's Avatar
Sounds good. Happy to help.
Old Apr 11, 2022 | 09:38 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to X156 forum...
Old Apr 12, 2022 | 03:06 AM
Graham.D's Avatar
GLA
Hi mate, sorry for not replying, been off line for a couple of days, poor signal offshore etc, I'm at home now anyway, I have done it the old fashioned way, inserting the key, like you suggested, it seems to have done the trick, hopefully that's it all sorted, really appreciate you helping, thanks,
Old Apr 12, 2022 | 09:06 AM
W205C43PFL's Avatar
You're welcome, thanks for the update on this. In that case if you are still under warranty then I think a simple software update to the EIS will help if you have a software version that is glitchy. There seems to be some communication error with the key and your vehicle through the keyless go system if only the keyless go system is not working properly or maybe if it isn't a software issue, if you eliminate the interferences it would work better.
Old Apr 13, 2022 | 06:48 AM
Graham.D's Avatar
GLA
Cheers bud, I am still not convinced it is actually fixed yet, but yes I have warranty on car, so if I need to I will give them a ring, thanks for all your help on this, just while you are there, if you don't mind, I am having problems with the Sat Nav as well, there is no memory card in for it as you can see in photo, I have rang MB & they quoted me £520, but I have looked on-line and I can get them for less than £100(Garmin), will the on-line one do the same job? Also, is there any way of getting Google maps or Waze on the Sat Nav? Thanks
SD Card?
Old Apr 13, 2022 | 11:47 AM
W205C43PFL's Avatar
SD Card?
Sounds good. Hopefully it all works out for you on the keyless go part.
As for the Sat Nav, since you stated in your original post that your vehicle is a 2018, it should have smartphone integration if it was optioned, if so plug your phone in and go to that section and you should be able to use Google Maps or Waze on your device. Speaking of Google Maps or Waze, I definitely do recommend just using one of those because at least you get the most up-to-date maps and live traffic and I would save yourself a few bucks from getting that SD card with the map software to power the built-in one that can easily get outdated.
Old Apr 13, 2022 | 12:46 PM
Graham.D's Avatar
GLA
Nice one bud, I have managed to get the smartphone integration sorted, like you mentioned, I will just stick with the Google Maps/Waze options, just glad I have that sorted, thanks again
Old Apr 13, 2022 | 05:46 PM
W205C43PFL's Avatar
You're welcome. Happy to hear everything worked out for you!
