GLB Class (X247) Produced 2020 to Present
Newest member not happy with Mercedes as a company
Old Mar 20, 2023 | 07:32 PM
Yeehawbob's Avatar
GLB 250
Talking Newest member not happy with Mercedes as a company
Hi,
We just picked up a used/loaner 2022 GLB 250 (7 seater) 7k miles with AMG and night package.
I have to say I am really unhappy with Mercedes as a company as they have taken everything out of the car and basically want to charge you for even the most basic of things, i.e.
1. No Jack if you have run flats. Yes they provide roadside assistance,but what if I am in remote or "no cell coverage area" to call for assistance. How long do I wait? what if I'm on a road trip with family and the tire is damaged beyond repair so they will tow me to nearest $tealer which may or may not have a loaner for me.
2. No hazards triangle. Just a simple item, if you created a space and clips for it then PLEASE give it away too. We will definitely thank you in time of need.
3. No Parking Sensors. This is just as basic as bluetooth these days and as a somewhat luxury brand one would expect it come standard and not cost $1200
4. NO Noise damper or Insulation under the hood. - this one burnes me a bit (pun intended). The engine noise is similar to if not more than what my 1988 300SD. They sure don't make it like they used to.
Please don't try to justify with "Low Price Point" as this is just a vent from an old guy who assUmed too much! wify wanted a not so big Merc so that's what she got. :-)
Old Mar 20, 2023 | 11:21 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
1. Most members are not thrilled with the MOE tires. And there’s no place to even put a spare in the 7 seater. However, other manufacturers were doing it as early as 2010.
2. My 2021 came with hazard triangles and a safety vest. I supposed that was taken out in 2022.
3. I’ve never had a car with oarking sensors, so I don’t miss them.
4. Agree with the hood damper. You can buy the one for the GLB35 and it’s not very expensive.
5. You didn’t mention no first aid kit.
Old Mar 21, 2023 | 07:57 AM
W205C43PFL's Avatar
Originally Posted by Yeehawbob
Hi,
1. Yup run-flats aren't good in my opinion, Reason they include it is so they can save weight, run-flats don't last as long as traditional tires, they are noisy, makes the ride less comfortable as well and when you do Replace it, it costs more than traditional tires, and then the cycle Repeats again. Some model MBs have a slime kit (I think they call it the TireFit?) and equip with traditional tires I think it was an option for some markets. Run-flats they expect you to just drive to the tire shop.
2. I thought that triangle was mandatory in Europe?
3. Yup not defending MB but Germans all do that, you need to pay extra for parking sensors.
4. Ah didn't expect to read this one
Edit: I prefer small vehicles too and wish they make small vehicles with luxuries of the higher tier. ie. A-Class size with C-Class amenities or even E-Class, sure charge more that is fine but some people prefer a smaller vehicle (well the minority though) I am part of the minority though, I also don't understand the obsession of big phones, imagine you have the cameras and hardware of their most expensive biggest offering in a compact form factor (well, that is a debate for another time).
Old Mar 21, 2023 | 10:42 AM
tbirdvet's Avatar
GLK350
I have Conti. RFT 19" and they are very quiet. The ride is no harsher than my 2014 GLK350 with 20" tires. I like the design because that are much better to not rupture a side wall when hitting a pot hole (I live in pot hole city). MY GLK has blown out the side wall twice. I also just compared the Cont. RFT vs non RFT and the cost difference was only $10.00. That being said I would guess that the ride would be softer with non RFT. I will have to wait to see how they wear as my GLB is a 2023..
Old Mar 21, 2023 | 11:59 AM
Vladimir Livson's Avatar
2021 Mercedes GLB250 4Matic
My issue with RFT is if you drive with a puncture, which you meant to do by design, you cannot fix the tire. And most likely you will have to replace both tires on the same axle, as the new tire will not have same wear as the old, which could cause other problems. Therefore a $20 flat tire fix becomes a $500 tire change.
Old Mar 21, 2023 | 12:07 PM
tbirdvet's Avatar
GLK350
Not entireley true. If you get a puncture and see the low tire pressure warning then stop and use the portable pump t(which you should carry with the vehicle) inflate then continue to repair location it can be plugged. The issue with RFT is if you loose air and then just keep driving you will damage the sidewall and then a new tire is required. When I had a side wall blow out (non RFT) not only did I have the change that tire but the other three as they had too much wear to just install one new tire.
Old Mar 21, 2023 | 12:17 PM
I agree that if you stop right away, plug and re-inflate tire you should be Ok (and I do carry portable air compressor and plug kit in the trunk), however that is not what RTF are designed for, thus no flat repair kit included with the car. They meant to be driven to the tire shop to be replaced.
Old Mar 21, 2023 | 01:04 PM
tbirdvet's Avatar
GLK350
I know what the design engineer believes but most of the time if you pick up a nail (as an example) you should not remove the nail. Just inflate back up, no need to plug. It will be a slow leak. Everyone should keep a pump and a can of slime in the vehicle with RFT or not.
Old Mar 21, 2023 | 04:41 PM
chassis's Avatar
2017 GLE350 4MATIC
Hi,
Welcome to the MB “experience”.
1. normal across brands
2. normal across German brands
3. GLB is an economy car, MB cheaped out on the GLB in many ways. They probably blame it on “the chip shortage”.
4. See economy car comment above.
Old Mar 21, 2023 | 07:10 PM
Yeehawbob's Avatar
GLB 250
1. Not really, my Honda and Lexus both have everything needed for tire fix. My BMW 5 series 2019 (may she rest in peace) had everything. A Jack, in my opinion is a must have RFT or not.
2. Hazard Triangle comment only because they have clips for it on the cover.
3. Even on economy car they can provide some items as standard and increase the price by that much. IF Merc is really trying to enter the "economy market" by being Cheap themselves then people are going to call it the "Cheap Brand".
Old Mar 21, 2023 | 07:50 PM
W205C43PFL's Avatar
FWIW, I never had side wall bubble and tire blowouts on traditional tires, I had run-flats and that is exactly what happened to me. The stiffer sidewalls of the run-flats is more prone to damage due to the weight in my experience. I am happy and glad that your experience was better.
Old Mar 22, 2023 | 12:31 AM
Odd Piggy's Avatar
I replaced 2 Conti MOE tires because of repeated nail damage to one. I replace both on the same axle if past 50% wear. The other 2 are fine and have over 40,000 miles on them. I’m okay with the tread life. But if you don’t repair them yourself, tire shops and the dealer will refuse because that’s what Continental recommends. If I had a 5 passenger version, I would just buy the Modern Spare aftermarket kit an store it in the back.
Old Mar 22, 2023 | 07:21 AM
I am sure that price point of GLB has a lot to do with missing "what should be standard" equipment, at least in pre Covid market. If MB can save $100 from every entry car they sell (I think they sell about 30K of "A" and "B" class a year in US) that comes to $3M of profit. Pre Covid with typical MB discounts of 8%-12% off MSRP, GLB was the same price as loaded Toyota Rav4 or Honda CR-V. That was definitely one of the deciding factors for me. Current market is totally different, however that could change again. Local dealer has a lot more cars on the lot.
Old Jan 1, 2024 | 02:47 PM
mbasun's Avatar
glb250
This did happen to me recently.
No safety vest, no jack, no repair kit, no first-aid kit, no triangle.
Old Jan 13, 2024 | 11:33 PM
MBenzdriver's Avatar
2023 GLB250
Can you provide the link for the hood damper? My engine sounds like a friggin Mack truck.. loud AF! 🤬
Old Jan 13, 2024 | 11:36 PM
2023 GLB250
I know for a fact based on what my dealer told me you must replace the tire if you get a flat which really sucks b/c its expensive. However I'm not sure if you must replace the second tire on the same axle
Old Jan 13, 2024 | 11:40 PM
2023 GLB250
Can you please provide link to purchase Modern Spare aftermarket kit ​​​​​​?
Old Jan 14, 2024 | 12:26 AM
Odd Piggy's Avatar
https://modernspare.com/product/2019...e-kit-options/
