Rear Fog Light
Is this appropriate to use in the states? Again, it lights up only the drivers said rear taillight a bit more. I have yet to check if it's the same lights that one using with the turn signal, but it's back there anyway. Seams like it would clearly help with visibility, though I found it a bit odd that it only does the one side.
Thoughts?
Not common in the US as there is no mandate requiring it. Have never seen this feature on a North American built automobile.
This high intensity light is meant to be illuminated during periods of inclement weather such as fog, smoke or heavy precipitation thereby preventing a rear end collision by a following vehicle.
It should not be used during normal visibility conditions as its brightness can dazzle following drivers.
Some US drivers misuse the light, I think, because they don't know what its real purpose is and its deleterious effect on following drivers when visibility is good.
Some US drivers misuse the light, I think, because they don't know what its real purpose it and its deleterious effect on following drivers when visibility is good.
I'm still surprised to see this on a US spec MB.
Many of my previous benz all had this feature. Heck, even my 98 ML320 has it.
So I went to the garage to get educated.
The light is mounted on the same plane as the backup lights at the very inboard of the tail light assembly. It consists of three leds' and to say they are very bright is an understatement. The further away from the vehicle you are the brighter they become. I was about 20 feet away and they were blinding. Trust me if this light is turned on when visibility is normal the guy behind you is going to be very pissed off. Much brighter, very much brighter than any other light on the rear of the vehicle. (see post 8)
When illuminated it is, of course, a very bright red. A closer look reveals the leds' are mounted at the very top of the assembly focused downward. The beam is turned from vertical to horizontal by a series of reflectors, much like the Corvette C7 taillights. An innovative design.
Can be useful if car behind has forgotten to turn on their lights at night or tail gate your rear end - they soon get the message, well most do, some who we jokingly categorise as Darwin Award types who will never get the hint !!!
https://mbworld.org/forums/glc-class...og-lights.html
Here I thought it was a dead switch since I didn't have fogs up front.
Using the fog light when it "..is very dark" is not what it is designed for and is insensitive to following motorists, dangerous, illegal (in Europe anyway) and downright STUPID.
If you have ILED headlights up front then you do effectively have fog lights .
When the rear fog light switch is activated, in conditions such as fog, falling snow, the shape of the headlight beam is altered to reduce reflection/glare.
