Storage container for center armrest compartment
2016 GLC 250d AMG pack, 2017 GLC Coupe 250d AMG pack , 2002 BMW 330Ci convertible, 2021 BMX X1 sD20i
Yes, Ebay. It's a shelf that fits under the twin lids. Has rubber liner to stop rattles and pre made hole to allow cables to pas through.
Prices vary from mid $20 to $50 for same item, ex Hong Kong or China.
Works well.
Works well.
Try this link, it's for a C Class, but interior same.
Mine fits perfectly.
http://www.ebay.com.au/itm/262150705...84.m1436.l2649
Cheers
Cheers
The following 6 users liked this post by Teckno:
Ddmccormack (01-10-2017),
easternshore (01-09-2017),
Gracie916 (02-04-2017),
maxoujm (09-27-2018),
RedwinGV (01-08-2017),
and 1 others liked this post.
Does the storage container make it any harder to latch the doors on the center console?
Cheers
Cheers
No issues with storage container.
Swing doors shut with ease, no effect.
With careful placement of USB charge cable you can still have cable extended to back or front seat passengers and still close doors.
I have a small "wallet" in top tray with fuel cards in it as well as USB stick connected by USB extension cable that passes through tray to fit sockets underneath.
All works perfectly for us.
Mine arrived, fits great, and solves the 'where to put stuff' issue instead of just a small pit. Had to trim the rubber pad inside with scissors slightly to make the pad fit better, but small deal.
Great news, glad I was able to help.
Enjoy the ride , cheers from The Land Down Under.
My center console storage unit insert arrived and I am quite impressed. EZ Pass transponder, cell phone (with charge access), and wallet fit nicely. Plus area for change. Do not understand why MB does not make this a standard feature. Have the same issue with our 2010 C300, but the storage area is not as cavernous.
Only problem with the EZ Pass transponder is that I have to take it out to be read. My 2014 Jeep Cherokee had a perforated storage unit on top of dash that permitted it to be read without removing.
Teckno,
Thanks for finding this thing and posting. The storage unit is probably the best value GLC accessory out there. I installed mine last week. Perfect fit and decent quality.
My only complaint is the rubber lining isn't secured in the tray and moves around. I guess this makes it easy to remove and clean but I'm going to try some double sided tape to hold it in place. Minor issue for a good value accessory.
Teckno,
This is now listed as Out Of Stock. I can't seem to find an alternative storage tray specifically for the GLC, has anyone else bought a different one that fits nicely?
Try these two sellers on Ebay.
For C Class, but I believe they will fit.
Good luck.
1. http://stores.ebay.com.au/virtuecomp...p2047675.l2563
2. http://stores.ebay.com.au/agatha2013...p2047675.l2563
Cheers from Oz.
Good luck.
Cheers from Oz.
Good luck.
Cheers from Oz.
Good luck.
Cheers from Oz.
I bought the one recommended for my C 300 and it fit perfectly. Again, thank you.
I also have the GLC 300 and the trays are not interchangeable. I did buy one a year ago for the GLC 300 and it also fit perfect but you must order specifically for the exact product
I bought mine from Amazon: , on Prime, no less.
Looks the same as the eBay tray, fits great, same problems with the size of the rubber mat.
VET11B (03-16-2017)
I won't tell you how to spend your money, but Amazon has rather permissive return policies: if you try it and it doesn't fit your console, you could always return it. eBay returns are generally more of a hassle. Plus, if you're a Prime customer, the free 2-day shipping is hard to beat.
