Couple GLC Niggles....
Hello folks,
Newbie here.
Have a 2016 GLC which overall I love. Lots more personality than the various Lexuses I have owned. However, do have one issue that seems to be getting under my skin.
Every time the car is driven after its been standing for some time (like overnite), so the engine's cold.....about half a mile from the start point, there is a gentle clunk from behind the steering wheel/console area. It does it almost about exactly at this distance. It does it only once and then drives perfectly all day long. Does it in all drive modes. Has nothing to do with road conditions or imperfections. I live in Houston where its been 80 degrees lately....so can't say its been cold. I would love to take it to the dealer but its a nuisance of a problem to replicate since it only does it when the car's not warm.
As far as I can tell, no gear shifts are taking place at the exact moment when the noise occurs. Any ideas? Is this something concerning?
Oh, and I have given up on Keyless Go. Does not work about 75% of the time. Works reliably when the key is in direct line of sight to the starter button area. Dealer says my other key - an Audi - is interfering. Who knows. Just annoying. Have changed batteries etc. No improvement.
I also have the screeching brakes, juddering wipers and have experienced the tire "crabbing" once in cold, wet conditions. The car is a 2016 RWD with 18 inch tires. I consider them part of the car's personality.
Thanks for any suggestions you might have.
Newbie here.
Every time the car is driven after its been standing for some time (like overnite), so the engine's cold.....about half a mile from the start point, there is a gentle clunk from behind the steering wheel/console area. It does it almost about exactly at this distance. It does it only once and then drives perfectly all day long. .
Agree, taking it to the shop is waste of time due to lack of reproduciblity.
Hello folks,
Have you tried separating your key from anything else to eliminate the possibility of interference?
Other keys can interfere. On opening and locking the car need to be careful of hand position. It can become confused if part of hand is behind handle and part is in front of handle.
In the past few days (since A service-may be just coincidental), I noticed something very similar. It sound like as "bird's feather flapping". My suspicion is it is something to do with air conditioning as it often coincides with the beginning of air circulation. I will report as soon as I learn something more definite.
As for the keyless, I will try separating the fob from the rest. Hand position is definitely not the problem. If it is interference from the other key, how do those of you with spousal vehicle constraints handle the second key? Keep them separate?
We keep keys separate. I have had no problems with keyless go. The cars are full of electronics that make all kinds of noises.
1. Separated the Audi/MB keys. Left the Audi fob at home. Keyless go worked flawlessly every time. So, that's that.
2. This is the more interesting one. The clunky noise I talk of has nothing to do with the car being cold. I can reproduce it consistently now. The trick is to turn off the car completely, step out and lock it. Then get in, start and drive again. The noise happens about when the first time the car shifts from D4 to D5 in comfort mode. Drives flawless thereafter. If I just stop the car, turn it off, restart and drive (without getting out or locking).....it does not happen. It seems that locking the car resets some system which is unhappy the first time it is called upon when the car starts all over. I hope that makes sense. Does not seem to be a mechanical issue or it would happen all day long. Any ideas? Something needs to be reprogrammed? The dealer recently applied some update for COMAND. Wonder if that did something since I do not remember hearing this before that.
Anyhow, if I can reproduce it.....I can go to the dealer.
Let me ask another question....
For the life of me I cannot figure out how to get the GLC to display if a door or hatch is ajar when it is switched to D or R. It does give me a warning but only once the car is moving and, even then, not which door is ajar.
Every car I have owned in the last decade displayed icons about doors/hatch that were ajar. Is there a setting someplace I am missing?
There is no indicator. It will tell you door is open if car is in reverse or drive in multifunction display.
Baggies,
I have noticed the "clunking" noise too. It happens consistently once passing about 30mph as I leave my neighborhood each morning. The sound comes from somewhere left and below of the steering wheel. Perhaps above where my left foot rests.
Because it happens at the exact same time while leaving my neighborhood and passing about 30mph, I believe it is something that is arming. Perhaps something to do with the brakes or another safety feature?
One thing is for sure, this car has a lot of electric motor noises. I think one should only be worried when they never run or never stop.
Baggies,
Next we tried to find another similar car on their lot to crosscheck against. Since there was no 16, we drove a 17. Guess what? It does the exact same thing. Now everyone's flummoxed.
Anyhow, he intends to look into it. Nonetheless, I know I am not imagining it and my car is doing exactly what other RWD GLCs in Texas are doing. So, I can live with that.
Unrelated note: Wrapping my Audi key in aluminum foil stops or weakens the interference enough to make keyless go work flawlessly. Now I need to go find a RFID blocking key fob wallet.
Yes, I know I need to find better things to do in my life instead of chasing car gremlins.
I am in Dallas. I have a 2016. Will see if mine does it. I will pm you. Mine is currently at the dealer being serviced.
usulbaggins (02-08-2017)
[QUOTE=Jetfuture;7049890]Baggies,
Same here. I wondered if it is the ABS. I use to hear that years ago with a car that I had and that was the explanation that I got from the service department.
2017 Mercedes-Benz C300, 2017 Mercedes-Benz GLC300
On my C300 it happens at ~10 mph and is hardly audible. Nothing else kicks in above that speed.
Agree, taking it to the shop seems waste of time due to lack of reproducibility.
Fix: Remove side vent and apply special lube to marked areas as per LI 68.10-P-058924
jeffzou (03-26-2017)
I had this "clunky" noise issue as well. It is a known defect. My dealer (MB Of Laguna Niguel) immediately fixed it. Here is their write up:
Noisy air deflector WP Tech 2240. Perform repair per LI Document LI68.10-P-058924. Apply special lubricant to air deflector shaft in housing.
That was this past Monday. No noise since then. It was resolved during my Service B at 20,000 miles.
FYI
Jeff
FYI
Jeff
2023 GLE3502W, 2024 GLC3002W, 1967 Pontiac GTO 4 sp (for sale)
Hello folks,
Newbie here.
Newbie here.
Seems like it would be easier to turn off the Audi key if you can than using an RFID key fob wallet.
VET11B (03-26-2017)
If you type juddering in the search field on this site, your computer screen will dim as the multitude of posts load up. There is a some controversy about what MB uses to deep clean a windshield. I have personal experience using original Bon Ami. Available at ACE Hardware. Picture below. General Motors actually repackaged it under their own part nbr for this condition.
The root cause is the wiper blades, they just suck, and MB doesn't seem to care. We replace hundreds under warranty, polish windshields, adjust wiper arms, etc. I bought a set of new wipers for my old CL, and they now dance across the windshield. Its not like my 15 year old car now suddenly needs a special cleaner on the glass. It needs wiper blades that don't have whatever these new ones have in them.
FYI
Jeff
FYI
Jeff
I thought, if not resolved early, this may lead to mechanical failure. Lube is an easy fix and MB is willing to do it. If it comes back I can always seek a fix.
It's just the adjuster motor for the far right air flap. The bulletin is so they don't get a bunch of techs replacing the motor when all it needs is a little grease, it's not a bulletin like a recall. There are thousands of bulletins related to the easiest, most direct way to fix common problems, to help get the cars fixed right the first time and minimize comebacks.
easternshore (03-28-2017)
