19 GLC car door LED projector
Old Dec 22, 2018 | 07:45 AM
GLC99's Avatar
GLC300
I’m planning to buy 4 car door lighting projector from Alibaba. Anyone knows what voltage I should get ? 12v ?
The stuff sold on alibaba is probably designed for China GLC version. Not sure if that will be compatible with the US GLC
Old Dec 22, 2018 | 01:59 PM
Rmlasalle's Avatar
2009 ML350 and 2018 GLC
I purchased LED projector door lights with the Mercedes logo from Amazon for $18 a pair. They were easy to install and work well.
Old Dec 22, 2018 | 02:10 PM
openwheelracing's Avatar
GLC
Pretty sure you can only install on the front doors.
Old Dec 22, 2018 | 02:19 PM
Rmlasalle's Avatar
That is correct. Only front doors are wired for light. At Amazon the lights for the GLC come packaged as two.
Old Dec 22, 2018 | 03:39 PM
GLC99's Avatar
GLC300
is that 12V bulb ?
Old Dec 22, 2018 | 03:47 PM
Rmlasalle's Avatar
Yes
Old Dec 22, 2018 | 04:14 PM
GLC99's Avatar
GLC300
Yes
only concern I have is that I’m worried that this may short circuit my car ? Maybe ?
Old Dec 22, 2018 | 05:09 PM
Rmlasalle's Avatar
I installed the door lights about 6 months ago and have not had any issues.
Old Dec 24, 2018 | 01:41 PM
fabbrisd1's Avatar
A gaggle of MB's
The install is quite straightforward - however - when installing the MB connector to the aftermarket socket - make sure the pins in that socket line up - sometimes the China pins are crooked and they need to be straight to accept the MB connector correctly.
Old Apr 16, 2019 | 10:59 AM
FROILAN69's Avatar
GLC X253
Hi.
Has anyone the door´s ghost light scheme, my car hasn´t in origen and i would like to rewire, also for the sunvisor lights.
Old Apr 17, 2019 | 03:52 AM
fabbrisd1's Avatar
A gaggle of MB's
The aftermarket "ghost" light is a simple plug-n-play replacement for the existing door lamps... have no idea on your "sunvisor" lights - keep the beat !
Old Apr 17, 2019 | 12:05 PM
FROILAN69's Avatar
GLC X253
Thanks for the answer, but i haven´t door lights, only a red plastic, no wires.
Old May 19, 2019 | 10:57 AM
Linh Luu's Avatar
GLC300 4MATIC
Extended rear lighting
The rear door puddle lights on our 2017 are lit along with our rear foot wells. I noticed that two recent GLC300 loaners didn’t have this extended lighting. I’m not sure what package includes the additional lighting.
Old May 27, 2019 | 12:34 PM
CaptainJack's Avatar
2017 GLC 300
As part of a two year anniversary update to my 2017, I found a set of factory led projectors for my front doors for about $150 ebay(dealership wanted $320!)
So much better looking than the Amazon stuff. Just the Mercedes star projected on the ground, no words. Took five minutes to install both.
Old May 28, 2019 | 01:03 PM
Jetfuture's Avatar
2016 GLC300
I installed the Chinese aftermarket puddle lights about a year ago. They are slightly distorted, and of low-quality, as expected. With that said, I just got done with a dealer 2019 C300 sedan loaner that had puddle lights in the same position (courtesy lights mounted on inside of door, not the uber expensive ones under the side view mirrors). They were VERY sharp looking. The car had 300 miles on it, and obviously did not have aftermarket puddle lights installed. I have tried to locate the Mercedes part number, but have been unsuccessful so far.
Old May 29, 2019 | 01:46 AM
fabbrisd1's Avatar
A gaggle of MB's
The OE Mercedes system in the door has a "step-up transformer/box" that installs in the door - car power lead connects to that kindof a intense box with heat sink case construction - then that box gets connected to the lamps - the box give's the "boost" for the MB projector lamps..
The China set runs off the straight 12V system - just light the regular light...
Old May 29, 2019 | 02:02 AM
2017 GLC 300
P/N A 213 820 45 03
Good luck on your search. Like I mentioned, the dealership in Portland quoted me $320. I mentioned it was a $200 upgrade at the time of purchase, but no luck
on the price, hence, Ebay. I will say, once you see the crisp, clean and bright logo on the ground, you'll love it.
Old May 30, 2019 | 02:24 PM
Jetfuture's Avatar
2016 GLC300
Originally Posted by CaptainJack
P/N A 213 820 45 03
Thanks Captain! Yeah, they are brighter and crisper for sure.
Old May 30, 2019 | 03:11 PM
Sigp232's Avatar
2021 GLE 450, 2017 GLC 300 4Matic, 2008 FJ Cruiser
Have a 17 GLC are they easy to install?
Old May 30, 2019 | 06:07 PM
2017 GLC 300
Mine is a 17, but it probably applies to the 16 as well.
Five minutes with the factory replacement. Some sort of prying tool(hell, a butter knife would work)
applied to one of the outside corners and it pops right down. Disconnect the wire and install it on the
new projector and it snaps back in....five minutes for both sides.
Jack
Old May 30, 2019 | 06:47 PM
Sigp232's Avatar
Jack
Nice thank you
Old Jul 27, 2021 | 07:56 AM
Ayeee's Avatar
C
https://www.ebay.com/itm/2Pcs-Side-Mirror-Puddle-Logo-Light-Mercedes-Benz-AMG-B-C-E-S-GLC-Class-/392989221942
