Glc 300 ru flats
I changed my run-flats on my 2020 GLC to non-run-flats in the first week of ownership. $145/each after discount. Put the new run-flats in the attic, and they will go back on the car the week before I turn in the lease 3 years from now, so I won't be hit for expensive new run-flat tires on the lease return.
I just received a used spare tire I bought on eBay, plus a jack and tool kit, and shorter lugs. $150 for everything. Looks it will all work, but I will try it on for size this weekend. Spare definitely fits under the trunk floor -- tested that already.
I will sell those spare tire items in 3 years from now and get my money back from them.
And I will save big over replacing the $350/each run-flats every 10-15K miles. Plus the non-run-flats can be patched without a problem.
And as an added bonus, the ride is luxurious again without those crappy run-flats.
I did the same. There is a place for everything under the trunk floor for the jack, lug nuts and wheel. The ratchet and lug wrench have a place in the side compartment behind the cover if, on the 2020, they didn't change that much from the 2019.
You're right about the run flats. They remind me of an old bike I had when I was young that had solid rubber tires. In fact, that would even be a better idea for the GLC, definitely no flats and you get the same ride!!
I like that idea, but don’t you think they will notice that you don’t have the run-flats and ding you? If they miss it, it’s a liability for them to sell a vehicle without run-flats that came with them since there’s no spare.
I also keep a plug kit and tire pump in the car. If you get a simple flat on a long trip, it’s better to patch it and keep going than to use the spare which can only go 50 mph. But the spare is good when you have a sidewall blow out in an area that’s hard to get a tow. I am ready for either case now.
I bought premium Bridgestone Driveguard runflats for $208 each.
