SERVICE A OR OIL CHANGE
That said, when I've serviced the cars I've purchased new (my wife's recent daily drivers) I buy the whole Service A or B, and like you said, there's always a coupon reducing the price. A nice bottle of rum at Christmas for my SA seems to guarantee that, lol.
You are responsible for maintenance, probably more so because you're driving a car owned by Mercedes. They'll perform the maintenance and charge you for it when you turn it in, if you decide to skip services.
You can do the math and make your own decision. Ask what the current charge for each service during the period you choose, add an inflation factor, and compare.
If this is a used car, consider how close are you to some of the more expensive services, like tranny flush, brake flush, or spark plug changes, that will be covered by a PPM. They will be included in the appropriate B Service, so if the 'B' is the one you mentioned, it will be included.
You may get advice to go to an Independent, but that doesn't apply, because prepaid maintenance is Dealer Service. PPM doesn't pay Indies.
A previous statement that the lease charge varies with your residual value is incorrect. The price is the price. If you include it in the lease, you pay interest on it as well. Like a set of floor mats.
Service A:
- Mercedes-Benz motor oil replacement
- Oil filter replacement
- Fluid level checks and corrections
- Tire inflation check and correction
- Brake component inspection
- Reset maintenance counter
- Cabin dust/combination filter replacement
- Brake fluid exchange
I do my own oil changes, tire rotations, brakes, brake fluid exchange, engine air filter, cabin filters and spark plugs. I leave transmission, coolant, O2 sensors and anything requiring their computer to others. Safe to say that an A-B-A is not worth it to me. If you're planning on an oil change every 10K and skipping the brake inspection, I don't recommend that.
As noted above and many times here, for a lease the PPM aid a no-brainer, as you only pay for 40-50% of it and the rest I added to your residual value. This is a marketing strategy for MB — another small incentive to lease, something for the F&I people to sell, and they get a large percentage of off-lease cars that have factory documented service. In my case I will pay about $900 net over my 42 month lease for 4 services.
If you don’t lease, it’s less clear. An oil change is $150-200 at the dealer and a brake fluid exchange is maybe $250. What’s missing here is the air/dust filters which are DIY (but a little bit of a PITA on the newer GLCs). So for an owner, you could get 4 services without filters done for $1,100-1,300 at the dealer. Even if you have the dealer do the filters, you’re probably adding $200 to every second service, so you’d be at $1,500-1,700 for the first 4 services.
Filters are a huge markup item at all dealers. Aside from their inflated parts prices, I get ads from all of the other dealers (non-MB) with “promo pricing” on cabin filters that are usually $129-179. Give me a break — changing the cabin filter in those non-MB cars takes 5 mins as it’s in the glove box (and parts cost like $15).
So if you want to DIY your own air/cabin filters, find the DIY video for your model year range (2020+ differ from the earlier years). Al’s decide if you want a dealer part or an OEM alike Mann or Mahle (don’t know which make GLC filters as I’ve never shopped for them).
FWIW, the cabin filter depends on your environment -- 2 year intervals are pretty conservative. Yeah, I've seen nasty pictures of ones that weren't changed for many years (and I've changed a few gross ones for friends since Acura and Honda use the same filter and I buy them 2-3 at a time), but if you're keeping the car 4 or so years, you'd probably want to change at the 2-3 year mark. Just saying that if you do yourself and you live in a cold climate, just wait till Spring to do it...
Same with brake fluid -- it's not that it goes bad, per se, but it absorbs moisture (it's hydroscopic) which hampers its effectiveness and causes corrosion if left unchanged for long durations. Acura/Honda suggest replacing it at 3 year intervals (irrespective of mileage), whereas BMW and Mercedes are 2-year intervals. Again, if you're keeping the car for ~4 years, you'd probably want to change it once, but it's not a situation that your brakes fail shortly thereafter if you don't change at 2-year intervals.
As noted above and many times here, for a lease the PPM aid is a no-brainer, as you only pay for 40-50% of it, and the rest I added to your residual value. This is a marketing strategy for MB — another small incentive to lease, something for the F&I people to sell, and they get a large percentage of off-lease cars that have factory-documented service. In my case, I will pay about $900 net over my 42-month lease for 4 services from carzinity.
