Strange whirring noise - is it the turbo?
I have a 2019 GLC 300 4Matic that I purchased recently. It has about 90K miles. I noticed it making a strange whirring noise a few days ago. It can be heard most at certain RPMs (lower RPMs - it either doesn't happen or you can't hear it at higher speeds/on the freeway). I've included a video of what it sounds like from the inside. Any ideas on what it could be? I'm probably going to take it in to have it looked at.
https://www.dropbox.com/scl/fi/0zz6c...789uz4n6p&dl=0.
My guess is that it's some sort of intake moan that occurs at that particular engine speed.
Remove the serpentine belt, if you know how, and turn all the pulleys, include alternator, ac, tensioner and idlers by hand and find if any, noisy one.
You can add some grease under the pulley bearing cover except ac and alternator. I did this for my minor noisy idler and a tensioner pulley.
The alternator pulley is special complicated one called OAD. Mine was bad and noisy, so I replaced new OAD with a special socket.
did u ever get this fixed and what was it having same thing thanks
] Try this https://forums.mbclub.co.uk/threads/...-30mph.282352/
