Post your AMG GLC Lowering option with Pictures please.
Old Jul 22, 2021 | 08:24 AM
  #351
spikiii's Avatar
2025 AMG GLC63S E Performance | 2021 AMG GLC63S (retired) | 2017 AMG C63S (retired)
Originally Posted by gserp4sox
That's interesting. I haven't done a ton of research on lowering modules recently, but I was under the impression that in the 2020+ facelift models, MB had a safety feature built into MBUX (ECU) making lowering via modules prohibitive. I have a 2022 on order and will be looking into lowering it. Thanks for the info.
Definitely works. The MBUX system puts up a warning message "Mercedes me functionality limited etc.", when you plug in anything into the OBD port but goes away after you remove the module from the OBD port and ignition cycle.
Old Aug 11, 2021 | 02:36 AM
  #352
Troyzy34's Avatar
2018 GLC63S
Thumbs up Vossen Wheels
Originally Posted by GM88
22 Vossen HF5 OBD Lowered 35mm
This car looks amazing and exactly what I would like to do to mine...what offset and widths are these wheels and do you have any rub problems?
Old Aug 11, 2021 | 11:24 AM
  #353
ronin amg's Avatar
2024 EQE AMG SUV . 2021 GLE AMG 63s Coupe
If that setup isn't rubbin he's not drivin...
Old Nov 19, 2021 | 02:58 AM
  #354
Soamv8's Avatar
2013 W166 Ml63 2008 aston martin vantage roadster
Lowering module 20mm lowered all around, spacers front 15mm and back 20mm
Old Nov 19, 2021 | 10:01 AM
  #355
sbradleyhall's Avatar
16-E350Wagon*sold 17-GLC43*sold 2018 GLC43*sold
Winter mode - -20mm front, -15mm rear. Module: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old Jan 14, 2022 | 02:56 PM
  #356
BlkSVT's Avatar
2019 M2 Comp / 2013 Q5 / 2020 GLC63
Originally Posted by Joshash151
-20mm all around via Amazon module. Fine service and product.
I want to buy spacers. What do you recommend? Will I get rubbing?
Looks Great! I have same color, same 21" wheels on my 2020. Front is dropped 20mm and rear 23mm (couldn't leave it at 20-20. That extra 3mm made a difference! )
I went with 15mm spacers on the front with the stock 21" PZeros, and 20mm spacer on the rear. I have >15k daily driver miles on it like that, and while I can get extremely slight rubbing with the right combo of pavement angle, wheels turned just right, and backing up slowly, there's no rub at all otherwise.
With my snows on it (Nokian Hakkapeliitta R3s in stock 21" size), it's a little worse due to the more square edged tires, but still no problem
FYI - I would get it aligned after lowering if you haven't. Mine was pretty far out before the alignment
Old Jan 16, 2022 | 12:21 AM
  #357
Bloom_Phaze's Avatar
Mercedes Benz AMG GLC 63s
I’m interested in a set sent to Japan but what material are the bushings made from…polyurethane? What are the materials used on the other hardware too.
Thanks for the Q&A and sorry if you’ve already posted this here amongst the amassed responses.
Cheers.
Originally Posted by K-Mac
Because of GLC models only having front and rear TOE (directional) adjustment.
NO FRONT CAMBER AND CASTER OR REAR CAMBER TO RESOLVE COSTLY, PREMATURE EDGE TIRE WEAR (not even front "one offset position" Camber / Caster bolts).
We saw the need therefore to re-instate from the 90's full front and rear adjustment. Same time replacing the 4 front and rear highest wearing bushings.
Front Camber and Caster, rear Camber (and extra Toe). Precise single wrench adjustment, accurately (under load, direct on alignment rack).
CATERING FOR OTHER THAN SHOWROOM HEIGHT CONDITIONS - day to day commuting encountering high cambered roads, wheel squat through lowering or load carrying, fitting wide profile tires/wheels, worn bushings, curb knock damage and the capability to correctly resolve steering pull!
AGAIN THE OFTEN QUOTED REASSURING:
"FULL FRONT AND REAR WHEEL ALIGNMENT" - REALLY MEANS JUST THAT!
OPTIONS AVAILABLE/MANUFACTURED:
FRONT ADJUSTABLE CAMBER & CASTER #503416 K $480
(LOWER ARM BUSHING KIT ALSO IMPROVED BRAKE AND STEERING RESPONSE)
FRONT ADJUSTABLE CAMBER & CASTER #503316-2 j $380
(WISHBONE UPPER/INNER BUSHING KIT)
REAR ADJUSTABLE CAMBER (& EXTRA TOE) #502226 K $480
(BUSHING KIT)
NOTE: Above KMAC Front upper wishbone inner bush kit is designed so can be fitted without arm or front wheel removal
ALSO MANUFACTURED
Uprated replacement bushings for the '6' multi link rear suspension arms - less twitch/flex loss of traction. Especially when applying power to lane change/overtake.
#502628 K $480
Delivery $30 one kit ($20 each extra)
Payment can be made by PayPal, Visa or M/Card
Old Jan 16, 2022 | 06:21 AM
  #358
RxBiz's Avatar
330i
Love the lowered look
Old Jan 16, 2022 | 10:03 PM
  #359
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Cheers.
Hi
Do point out we have the experience of being the longest established aftermarket manufacturer of Hi Performance bushings - 58 years (1964). Continually testing, proving, developing in "all out competition racing".
Specially formulated from elastomer material running on ultimate nickel chromed hardened steel bushings.
DHL Express air delivery to Japan (and worldwide) current special is $40 one kit $20 each extra.
Old Jan 17, 2022 | 05:06 AM
  #360
Hhhhmmmmm, ok thanks.
Old Feb 21, 2022 | 05:54 PM
  #361
Hollywood619's Avatar
Looking for E55
This is the best looking OEM Plus setup I’ve seen so far. Can you pass along where you purchased the extended wheel bolts from?
Old Jun 13, 2022 | 05:40 AM
  #362
Oliver Chug's Avatar
AMG S63
https://mbworld.org/forums/s-class-w...ml#post8579320
I've written here before about how pleased I am with my lowering module. I bought 2 of them - for the S63 coupe and the GLC63.
Below is a photo of my GLC63
Old Jul 12, 2022 | 01:58 PM
  #363
WIKDWGN's Avatar
2018 E63S AMG Wagon, 2020 Audi R8 Performance
Does anyone else have inner front tire wear issues with their lowered GLCs?
I was told the car was aligned when it was lowered (bought it lowered). I didn't verify the alignment and didn't notice the tire wear until it went flat on me last weekend. Right side is just as bad.
I know with my W213 E63s Wagon that there isn't a way to properly align the car with the factory suspension hardware. Just curious if there is a cure for the GLC.
Old Jul 12, 2022 | 11:34 PM
  #364
K-Mac's Avatar
SPONSOR
There is only front and rear Toe directional adjustment OEM. All to do with cost savings and ever increasing speed of auto assembly lines !
To resolve costly premature edge tire wear we therefore manufacture for all GLE models Front Camber adjuster kit #503416-1i at $345 (less cost then one hi-performance tire).
Replaces lower arm inner 2 bushes. Fit on car without need for arm removal. Bush extraction tool included. No special tools required.
Unique patented design allows precise single wrench adjustment accurately (under load) direct on alignment rack.
FOR THE REAR:
#502226K $480 (Coil / 4MATIC)
#502326K $480 (Airmatic)
#502326-1K $480 (AMG models)
Above provides Camber (and extra Toe to compensate) replacing lower arm inner bushings. Also fit without need for arm removal.
See spoiler re other kits manufactured.
Spoiler
Experience Of Resolving OEM Suspension Shortcomings Since 1964 !
Old Jul 15, 2022 | 12:47 PM
  #365
I_love_ICE's Avatar
C63
2022 lowered 20mm all 4 corners. I like having some travel for the crappy roads in and around DC/MD area-
Old Jul 20, 2022 | 09:22 AM
  #366
Markshagal's Avatar
AMG GLC63
Wow the rims just look beautiful! Is that a Vossen? I'll take a picture of my lowered GLC63s soon and show you friends!
Old Jul 29, 2022 | 01:46 PM
  #367
Loc's Avatar
Loc
2013 GLK350, 2013 E350
I finally lowered the car with 20mm preset 1. Thus far very nice. I will try the 2nd setting of 30mm after a few months.
Here is the video link:
Old Sep 23, 2022 | 12:56 PM
  #368
Ogli's Avatar
AMG E63s
ordered 2nd version 20\40 of MWM lowering module (mwmods.com) for the GLC43 AMG
-40mm on the pics
also ordered Dynamic Select memory mode module to save Sport mode as default
So happy
Old Nov 27, 2022 | 03:16 AM
  #369
Ed99's Avatar
E63s AMG
Anyone know what is the sweat spot before too much negative camber wearing out the tires? Looks like the best looking stance is around 32mm front and 37mm rear but anyone knows what the negative camber you will be running with those numbers?
I tend to be ok with anything up to -2.1 to -2.3 usually you can get away without any negative camber wear on the tires.
Old Dec 30, 2022 | 08:58 PM
  #370
SilverBullet18's Avatar
C450,GLC 63,VW GTI
I second that! What's the sweet spot before it messes with camber.
Old Dec 30, 2022 | 09:53 PM
  #371
C450,GLC 63,VW GTI
Originally Posted by Georgvi
I ordered the module on Amazon, I chose a version with preset heights of -20mm and -40mm. I think this version of the module is more suitable for GLC and now I love how it looks.
is this -20mm in comfort?
Old Dec 30, 2022 | 10:39 PM
  #372
C450,GLC 63,VW GTI
Old Jan 1, 2023 | 11:01 PM
  #373
shiraki's Avatar
e55
-33 & RYFT Forged Wheels
Old Jan 21, 2023 | 12:33 PM
  #374
GLCya63's Avatar
2020 AMG GLC 63
Renntech HSM 32mm Front, 35mm Rear in the pics in C mode. But I usually daily 12mm/15mm F/R.
Old Jan 21, 2023 | 01:37 PM
  #375
C450,GLC 63,VW GTI
The brabus module lowers 15mm front/rear from stock (plus add another 15mm when you do put it in sport). Is that safe to assume that's the max limit in order to not mess up the camber/tire wear.
im hoping we can get away with 20mm without any consequences.
