Car going into limp mode (mods : racechip)
Old Oct 7, 2019 | 04:52 PM
Arta.xerxes's Avatar
Glc43
Hello everyone
i have a glc43 amg and have been riding it for two years without any problems at all until recently which car goes into limp mode every now and then
When I bring up the AMG menu it doesn’t show any boost and car accelerates much less than normal. And also there’s a racechip installed on the car as well.
any ideas 💡?
Old Oct 7, 2019 | 05:58 PM
KingMonkeyJr's Avatar
GLC 63 AMG, Trackhawk, X3M
Use a scanner and see what the codes are.
Old Oct 8, 2019 | 03:07 AM
Glc43
Checked it
The code is p0106
says the manifold boost pressure sensor us faulty ( outside permissible range) i think it’s due to the racechip
no CEL btw
Old Oct 8, 2019 | 07:51 PM
do you have loss of power? Any noises at idle?
clear the code and back to normal?
Old Oct 9, 2019 | 12:54 AM
Glc43
no noises! The car gets back to normal randomly
no specific pattern.
Old Oct 9, 2019 | 12:55 AM
Glc43
About the power , no turbo boost at all, the turbo boost pressure gauge displays nothing
Old Oct 11, 2019 | 12:35 PM
I have heard of the intake manifolds blowing up as they are plastic. A couple C63s guys have said it happened but I couldn’t imagine a race chip being able to do that..
they are located under the airboxes running under the spark plugs on both sides of you can take a look and see.
Old Oct 13, 2019 | 01:08 PM
Glc43
Thanks for the reply. Can limp mode happen randomly because of this?
Old Oct 13, 2019 | 01:09 PM
Glc43
I removed BMC air filters btw cuz I thought it might be because of them. The area i live in is dusty
Old Oct 20, 2019 | 10:54 AM
jim04clk's Avatar
It’s obviously the race chip putting the boost sensor to far out of stock parameters. Not a fan of these or any piggybacks. Get a ECU tune or leave it alone.
Old Oct 21, 2019 | 11:52 AM
ParadigmDawg's Avatar
AMG GLC 63s Coupe
Agreed................
Old Oct 21, 2019 | 03:58 PM
Glc43
I thought the same! But this limp mode thing did not happen before ! Why is it happening now? I’ve been using racechip for a year now
Old Oct 21, 2019 | 04:10 PM
Are you able to take logs with the race chip? Id say if it is possible to do so and see what is crashing/failing under the parameters.
Old Oct 23, 2019 | 02:08 AM
Glc43
@KingMonkeyJr sry mate, I can’t
but I forgot to say when this happens “A” button , eco start/stop function is disabled! I can now predict when this “limp mode” thing gonna happen! Before happening it seems the car is choking on something then suddenly turbo shuts down but no noise etc
Old Oct 23, 2019 | 05:47 PM
Is this during full throttle? Only thing I could think of if the car is boosting too hard and running out of fuel.
Old Oct 25, 2019 | 06:13 AM
Glc43
@KingMonkeyJr i removed the racechip and now it’s ok! The question is why such a thing has not happened through a year and half and it’s happening too often all of a sudden?! And yes during full throttle
Old Oct 25, 2019 | 08:56 AM
affalterthought's Avatar
Blk/Blk GLC43 AMG WAGON
Is the Race Chip your only mod ?
Old Oct 25, 2019 | 09:15 AM
Ever since my shop (reputable shop up here in the NE) told me these engines (43's) do not like the boost cranked up aggressively I was super cautious and have since backed off until I am ready
to have professionals spend the time they need for my individual car. Too much **** can go wrong with these complicated engines it just makes me so leery of ****ing around with it in the first place.
Last thing I want to do is be holding the bag on a roached engine.
Old Oct 25, 2019 | 04:51 PM
Glc43
@affalterthought yes plus a pair of bmc air filters which I removed recently. I haven’t had this problem until recently which is happening frequently now after a year and half of racechip installation. That’s what bugs me right now
Old Oct 25, 2019 | 05:02 PM
Maybe some sensors have gone bad and under load it is going into safety mode. Id just take it to the dealer and see what they can do. Just mention you had the codes but since it has disappeared.
Also one question what settings on the race chip are there? Boost parameters?
The cars are sensitive as the LPFP seems to have the voltage toned down quite a bit. I am pushing 23psi right now and having no fuel issues with my new tuner.
Oh also running E50 currently and working on a E85 tune with them as well. Thing is a monster!
Old Oct 25, 2019 | 05:09 PM
After reading a little I think it is your Boost Manifold Sensor. It could either be faulty from the Racechip or faulty from factory. Id reach out to racechip and see if they can send you a replacement to see if that fixes it. If it doesnt then Id assume taking it to dealer.
After reading a little more seems like this happens to a couple people. Looked through the Bmw forums and a couple guys said the same thing. After driving one year they were going limp mode. I would think it is the Racechip itself maybe got a spark when the car was turned on and screwed the sensor.
Do yourself a favor and get a Tune. It is so easy nowadays with the OBD2 access.
Old Oct 25, 2019 | 08:27 PM
Man I would do the exact opposite of running to the dealership. Seems risky IMO. I would find a reputable tuner who knows these cars just as well as any MB certified tech. I would not want some MB tech sniffing around who might find some log / files. Then you are literally at the mercy of the tech and that dealership. If they are cool, no sweat; if not you are fu#$%ng toast. Warranty no bueno. I don't know maybe I am over thinking things.
Old Oct 26, 2019 | 01:41 PM
Mr. J's Avatar
C450, GLC43
Loose cnxn at the boost sensor clip is a pretty frequent cause for issues similar issues with piggy backs. The clip is a little tricky.
Old Oct 26, 2019 | 01:47 PM
Mr. J's Avatar
C450, GLC43
Dealer won't do anything beside check connectors and clear any codes. There's a small risk they may flag the car a potentially modified, but I doubt it. They definitely will not be poking around in log files since they will not have approved labor hours under warranty coverage to do this even if they had the know-how (most do not).
But most importantly, the dealer won't really do anything to help.
Old Oct 26, 2019 | 02:12 PM
Mr. J's Avatar
C450, GLC43
I disagree. Racechip and Dinan are really mild tunes that are safe for most applications. BMS JB4 is more powderful but also has more safety features baked in. This can't be said for all the canned ECU flashes out on the market right now. Some are great and others not so much. There really isn't any reason to get an ECU tune unless you are going stage 2 or beyond or if you really want to add a burble tune to a car that doesn't have it stock.
For cars running stock + tune, a piggy is the best option. And JB4 is the best of the piggies.
Now if you're building a heavily modified beast like Kingmonkey Jr, a custom ECU flash is really the only option. But his ride is a Unicorn. You're not going to find many beasts like that out in the wild.
