LED Headlight upgrade
I can't believe that an originally $70k priced vehicle comes standard with cheap Halogen Headlights. My old VW even had HID headlights
which were much brighter than these crappy lights. I am tempted to return the vehicle to the dealer and start my search over again.
My question is: Are there any options out there that would replace the OEM Halogen Headlights with an aftermarket LED Headlight?
If so how much do they cost and are they plug and Pray?
Thanks for the help in this matter. If there isn't a viable option I may just return the car tomorrow.
The dealer wouldn't take the car back so I searched and searched and these people in the United Arab Emirates where the only place I could find them. You may want to chat with the guy on the website to make sure you order
the correct ones. It should be the Normal to Dynamic LED Headlamps that you want but chat with the Sales guy just to be sure. I don't have the Part number anymore but after chatting with the sales guy he put the order
together and also set up the least expensive shipping option. It roughly took 10 days for them to arrive and you will get a tracking number. After the shipment hits customs in the US it will sit there for a few days until it moves
on. Before I was able to check the Huge package arrived at my doorstep. I made sure the Lamps were not damaged which is almost impossible the way they are packaged. And they were in excellent condition. Make sure you
either can install them yourself or have a shop that will able to handle it. I knew of a shop that did all my work on my Audi and VW's. They also do Porsche and other Exotic cars and they installed those lights in about 2 hours.
I felt better for them to do it then for me to screw it up. Seems you do need to drop the bumper in order to install these monsters. Otherwise it is pretty much plug and play. The only thing the shop needed to do is reuse the OEM
rubber weather seals from the Original headlights. I guess that is a rubber seal that goes between the headlight and the bumper. Not really sure. All I know is they did a fantastic job. Overall it did cost me $1220 installed but the results
are totally amazing. It really lights up the road ahead. And yes, the car otherwise is Amazing for an SUV. The Performance blows anything I owned previously out of the water. It's as fast as my Supercharged Mustang with almost
600 HP was before I sold it. I did tune the 43 and it does now have 430 HP and 480lbs of torque. I also had the Auto shut of and auto start disabled. That thing was annoying to me. Now this thing is even a bigger beast than it was
before. I haven't taken it to the track but may invest in a Draggy to see what it can do. But the Butt Dyno says this thing can fly. The Tune I did was the Stage 1 DME tune. They had a Black Friday deal for right under 1k. No more speed limiter and you can chose a few other things like more burble sound etc. I personally don't care for that snap crackle and pop sound so I just left the sound the way it is. I think it sounds awesome from the factory. For dealer trips you can switch back to Stock with the handheld unit they send you. Anyway, Good Luck. I am sure you will like the car a lot better with decent lights.
Headlamps. Actually those LED bulbs were worse than the Halogen replacement bulbs. The best results I have gotten were with the Philips X-treme Vision Bulbs which were a lot better
than the OEM Halogen Bulbs. Two shorts falls on those bulbs is that they don't last long and they still lack the range of a true LED Headlamp. So while it is a much less expensive
option it's not what you would expect from a 70k+ vehicle. Heck, my neighbors Buick had better headlights than my Mercedes. Whoever owned that Mercedes before me ordered every option
possible except for cooling seats and LED headlights. Big Mistake. At least in 2020 Mercedes made them Standard in the AMG43 GLC models.
They said it’s standard programming that shops can do but can you confirm this and maybe provide further insight?
Thanks!
Thanks!
headlights to their LED headlights and the guy I talked to said it's a straight plug and play process. The shop that I took it too didn't have to program anything. Just take off the regular Halogen headlights
and replace them with the LED headlights. I would talk to Beta Auto again and make sure you mention that you are upgrading from a standard Headlight to a LED Headlight and not from Static to Dynamic LED.
You do want the Dynamic LED Headlights. Just make sure they understand that you want to upgrade from standard Halogen Headlights.
One shop is willing to do the programming, the other one NO because often time it never worked on aftermarket lights.
when switching the Halogen Headlights on the AMG 43 to the Dynamic LED Aftermarket headlights from Beta Auto Parts. It was a straight Plug and Play
swap with the only thing the shop had to do is reuse the rubber seal around the headlights from the OEM units and put them on the New LED Units.
I don’t know if that means smaller projectors and impact on light output/performance too. Can you please comment.
Thanks.
Thanks.
Thanks.
Btw you really have a vendetta against those halogens lol I don’t blame you.
B. The struggle is REAL with these POS halogens. They are embarrassing, literally.
To retrofit dynamic LEDs is not simple. It is in-depth coding as well as additional hardware.
That being said, it looks like these replica LED lights do make a huge difference in appearance over the stupid halogens.
Thank you!
