GLC 43 p0299 code
Old May 18, 2026 | 03:49 PM
16GLE63s800's Avatar
GLC 43 p0299 code
Running into this p0299 code when hitting full throttle on my GLC 43 that then throws the car into limp mode. Any ideas on what might be the problem would be greatly appreciated. I would rather not deal with a shops as some have suspected it needs a new turbo which I find hard to believe being under 50k miles and operating fine below full throttle.
Old May 18, 2026 | 04:29 PM
W205C43PFL's Avatar
Yes that is a turbo code but most likely a wastegate issue.
https://mbworld.org/forums/c-class-w...2015-c300.html
https://mbworld.org/forums/c450-c43-...boost-jb4.html
https://mbworld.org/forums/c-class-w...299-fixed.html
Old May 18, 2026 | 04:32 PM
W205C43PFL's Avatar
More threads that might help:
https://mbworld.org/forums/c-class-w...eparately.html
https://mbworld.org/forums/c-class-w...eleration.html
Old May 18, 2026 | 05:05 PM
p_gill's Avatar
E400 Cabriolet
I’m going to assume that you have the M276 twin turbo.
Based on that recommendation you should see what the C43 enthusiasts are talking about.
start with this thread
C43 with low boost pressure
To answer your question explicitly
1. The check valve on the vacuum pump that supplies vacuum to the turbo wastegate actuator is known to fail and when it does boost will suffer
2. The MAP sensor on my M276TT failed and this sensor is how the ECU knows that you are under boost (this could be your issue)
3. The vacuum applied to the wastegate actuator is controlled by a solenoid and if it is not working properly then your boost will be affected
4. The intake air for the turbo has a diverter valve that can fail and if it does then you won’t get as much boost from your turbos (there are two valves, one for each turbo)
Take care
Paul
Old May 18, 2026 | 05:45 PM
W205C43PFL's Avatar
Take care
Paul
Yup OP has that engine. Thanks for chiming in.
