Dashcam options
thanks in advance. Seems a better option than going all the way to cargo fuse panel.
Feedback I get from other GLS owners that have the OEM dashcam is that the quality is quite poor. Not even close to aftermarket dashcams that have been installed as per this thread.
They said not to bother getting it.
I personally have not seen the quality but I am very happy with my Rove dash cam which has 4K video.
The down side is that most (as of today) built in one does not have a high resolution in today's standard.
Some online comment suggest that the force of airbag should "cut" the cable when it deploy. Personally I don't want to risk myself or my family, and I don't want to find out how the cable affects the airbag when it deploys if something does happened. Even if it is true (that force of airbag deployment will cut the cable), I still wouldn't do it.
Two camera is definitely worth it if you are willing to run the wire. But I mentioned this before somewhere else, any dashcam is better than no dashcam.
This is what I am referring to.
I see some YouTube video suggesting people to wire it that way, and it will be in the way of the side curtain airbag.
As for the headliner, I never remove one so I can't say how easy/hard it is
The way I wired mine is by removing the a-pillar, zip-tie the cable following the factory wire harness, following the wire below the door trim piece to the back.
It does mean I need a longer cable, but at least I don't have to worry about the airbag.
As for under the headliner, would sunroof be an issue? And if you are just pulling without removing the headliner, wouldn't it run the rise of moving factory wire (or whatever they have hidden up there?)
With the way I route the cable, I have to get the 18ft one. the 15ft one just a bit too short. (I think 15ft would be just enough if you can figure out how to remove the rear seat side cushion. I wasn't able to figure that out so have to route it around.)
As for the rear camera cable, I use the 20ft one and I have a bit extra left.
Before pulling the trim off, you have to pop off the plastic ABS sign with a pry tool. Also, all of the trim is easier to remove once you pull out the door seal. Next step is to pop off the top clip of the trim adjacent to the glove box / dashboard. There are no screws in any of this trim.
Before putting all of the trim back into place, re-seat the door seal first.
Top clip of A Pillar trim. This gives you an idea of which way to pull to remove it. Pull towards driver's side.
Close up of the top clip of the trim adjacent to the glove box and dashboard.
This trim adjacent to the glove box and dash has be popped off first (just upper part) before removing upper A pillar trim.
A Pillar trim. Bottom doesn't have a clip, just a spacer block of some sort.
A piller trim top clip
pic of the entire A pillar trim
)Also, I think when putting back together, its actually easier to put the trim piece first before the door seal, since some (or all?) pieces actually slide behind the seal.
I just realized I forgot to snap pics of the bottom trim of the door. I tucked the wire underneath the carpet after removing that trim. I plan to have my backup dashcam battery underneath the front passenger seat. I travel a lot so I thought the location would be easier for me to turn off the battery when I'm away for weeks at a time. The backup battery will be powering two 1ch cameras.
)I also end up having 2 batteries linked together for my 2 channel setup, and I am usually able to charge it from empty to full in maybe about an hour of driving? So I just leave it connected with the ACC power and power on/off with the car (to charge the battery).
And the reason I have my battery in the trunk is because it has more room, plus I am using direct wire (shorter cable) to connect to the fuse box, and a longer 12v cable between battery and camera on the front.
)For me, if I remember correctly, I zip tie to the factory harness also for the trim piece below the door. I didn't remove the trim under b-pillar, but there should be enough room to tuck it underneath.
https://www.blackboxmycar.com/produc...m-battery-pack
I'm hoping I'll get 12-14hr runtime for two 1ch cameras.
I was able to keep my 2CH running in parking mode for around 30 hours, so I think you should be fine with half the time (but probably worth test it)
For mine, since it is a 2-channel camera, if I want to turn off the camera before battery reaching 0%, I can just disconnect the power cable from the camera side, since it is just right next to the rearview mirror.
