19” Bridgestone Alenza tire wear
Old Jun 13, 2020 | 11:27 AM
MercOne1's Avatar
2020 GLC43 | 2020 GLE350 | 2014 E350 (sold)
I’ve got the standard 19” wheels with Bridgestone Alenza tires. After 8,200 miles, tread shows 7/32. At this rate, they’ll barely make it to 20,000 miles. What are others getting?
Old Jun 14, 2020 | 09:32 AM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
Are those the extended mobility tires? I understand they are known to give poor treadwear life.
Old Jun 14, 2020 | 10:43 AM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Bridgestone Dueler Alenza tires
Hmmm....Bridgestone rates them at 600 or 700 for tread wear, which is very high.
Old Jun 14, 2020 | 11:14 AM
TexAg91's Avatar
2020 Mercedes GLE350 4Matic; 2023 Tesla Model Y
What is the tread depth a new Alenza tire? 7/32nd is 1/32nd away from a 1/4 inch. If you do think it’s wearing fast, have you had Mercedes do a 4-wheel alignment?
Old Jun 14, 2020 | 11:23 AM
Bridegestone Dueler Alenza Plus
Per The Tire Rack, the tread depth is 11/32". Generally, 4/32" is considered minimum. Looks like tread wear is listed as 540, but that's still pretty high.
https://www.tirerack.com/tires/tires...=55WR9HLALNPXL
Old Jun 14, 2020 | 11:25 AM
TexAg91's Avatar
Found the answer to my own question. According to tire rack it is 11/32nd. So you wore 4/32nd off the tire (1/8 of an inch) in 8.2k miles. Is that on the outside of the tire or the inside of the tire? if it’s the outside, it could be one two things. It is either out of alignment, or you’re taking curves too fast. That does seem like very excessive wear.
Old Jun 14, 2020 | 11:30 AM
MercOne1's Avatar
The 7/32 measure is front driver side tire. Rear driver side is 8/32.
Same measure on inside, middle, and outside of tire.
Old Jun 14, 2020 | 11:44 AM
Tire wear
With 7,400 mi. on my 21" Pirelli Scorpion Zeros they have only worn 1/32"; from an original 10/32" they are down to 9/32" F&R. They have a tread wear rating of 500, compared to 540 on the Bridgestones. So, your wear is very high - better quit those 4-wheel burnouts!
