winter wheel/tire combo for 2021 GLE63 SUV
Old Dec 2, 2020 | 07:25 PM
GLE wannabe's Avatar
E320
Has anyone tried buying this winter wheel/tire combo shown on MB website https://www.mbusa.com/en/winter-whee...ire-assemblies
Tire Rack says they don't have specs of OEM wheels/tires so they can't recommend/offer anything. Anyone have any suggestions?
2020-Present GLE SUV
V167 (Mercedes-AMG GLE 63 S 4MATIC+, Mercedes-AMG GLE 63 4MATIC+)
  • 21-inch, AMG 5-twin-spoke wheel, High-Sheen Titanium Grey
  • Front axle: 275/45R21 SCORPION WINTER MO XL
  • MSRP: $1,112.00
  • Rear axle: 315/40R21 SCORPION WINTER MO XL
  • MSRP: $1,201.00
  • Part #BQ6670078 Front Axle
  • Part #BQ6670079 Rear Axle
Old Dec 3, 2020 | 09:37 AM
marchgroupinc's Avatar
2020 GLS580, 2023 Corvette Z06
I found MB wheels overpriced. I went with Vossen HF series, stronger, lighter, less $$ and made in Miami. Made to custom specs. in only 3 weeks. - mine pretty much match the MB spec.for size and fitment.
Old Dec 3, 2020 | 02:03 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Winter rims/tires
  • MSRP: $1,112.00
  • MSRP: $1,201.00
315s in rear are pretty wide if you will see any snow/ice. Most prefer a narrower square setup for Winters.
Old Dec 3, 2020 | 06:10 PM
E320
For sure easier to drive a sled than a tobaggon.
I've contacted 3 MB dealers and they claim these packages don't exist.
Also tried chatting with Vossen through their website and they put me on hold forever. Just gave up.
Old Dec 3, 2020 | 06:11 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
The vehicle will handle 20” by 8 1/2 or 9” wheels-square is good as Greg suggested. Then you have a large selection of the best tires at a low price. ET 35 to 45 will not be too wide. My set was about $2300 with TPMS-Tire Rack purchase except for a deal from Costco on the Michelin PA5 Winters. Winter tires are in short supply this year.
Old Dec 3, 2020 | 06:15 PM
Ron.s's Avatar
Couldn’t add these to the previous post.
Old Dec 3, 2020 | 06:19 PM
E320
What wheels did you get and where from? When I called Tire Rack, they refused to recommend anything for the 2021 GLE 63. They said they didn't have specs for the car.
Old Dec 3, 2020 | 06:24 PM
E320
Just saw your picture Ron. Nice wheels.
I'd like to avoid having to use spacers and extra long lug nuts to clear the brake calipers if possible.
Old Dec 3, 2020 | 06:37 PM
Ron.s's Avatar
Mine were on my 450 but I have a GLE 53 coming any day and have researched fit...as well as I can without actually installing them. I have the larger brakes on my 53...same as the 63. I checked with my SA to be certain and he went into Netstar and was able to option my build with 20” wheels but it also required the Summer Performance Tire. So I’m convinced the 20’s will clear the brakes and a lower offset will move the wheel out from the brakes. I don’t know of any aftermarket staggered wheel options. I also can’t find anyone that will recommend anything but tires for the 2021 GLE AMG models.
The other issue is that the aftermarket wheels take a conical seat M15 Stud bolt. Tire Rack and a few others furnish the bolts. I bought black ones from Otis LA.
Old Dec 3, 2020 | 06:39 PM
Ron.s's Avatar
Mine are et45-no spacers needed.
Old Dec 3, 2020 | 06:54 PM
Winter rims/tires
I'm using 20x9 W166 wheels (drilled out for larger lugs) & 275/50 tires. As Ron says, 450 w/ AMG exterior and 53/63 front brakes are same size so 20s should fit. I'm using spacers in rear, but that's just if you want to fine tune to perfect stock fit.
Old Dec 3, 2020 | 07:25 PM
threeMBs's Avatar
Only MBs - the best or nothing
GregW, there's a poster with 63 and he states that his front rotors are 16.5" diameter (I questioned him on that and he was kind enough, he said, to measure and indeed confirm they are 16.5" and since I do not have excess myself I have to take his word). Since you've done a lot of "wheel work" on your 450, did you by chance measure the front rotors' diameter? There's no way they are 16.5" on 450, that is for sure. Are they even 15.8" on 450?
Edit:
this is that post - https://mbworld.org/forums/gle-class...ml#post8195690
Edit #2: It looks to me that for '21 for 450 with AMG exterior, they downgraded the front rotors vs. '20 - solid instead of perforated rotors, and diameters look definitely smaller than on '20. Since I never paid attention to 167 GLE for MY '20 (since there were no AMGs), but started for MY '21 (since I am interested in AMG) it seems to me that since for MY '20 there were no 53/63, maybe MB in fact did use (perforated MY '21 GLE53) 15.8" rotors on front of '20 450 ("AMG" exterior) and '20 580. However, for MY '21, at least for 450 ("AMG" exterior) that I've seen on dealer lots and on their sites, all have solid and visibly smaller diameter front rotors than 53's rotors. So "53 front rotors" were a one year run for MY '20 450"AMG"/580 but not anymore.
Old Dec 3, 2020 | 08:04 PM
Ron.s's Avatar
High Performance brakes on the AMG GLE 63...optional on the 53:
“Enormous 16.5-inch front discs are grasped by powerful 6-piston fixed calipers. The one-piece rear discs measure 14.6 inches”
Old Dec 3, 2020 | 08:15 PM
tery's Avatar
CLK320
I have aftermarket 20x11ET 58 with blizzak 285/50-20. Still a lot of room left on the rotor diameter. But I would go 21” for 63 winters
Old Dec 3, 2020 | 09:08 PM
Edit:
As Ron noted, apparently there is a 'high performance" option for the 53 that may now be standard on the 63. Previously this was a European-only option. These are fixed caliper, as opposed from the cheepo floating caliper on the lower models. I have not measured, but 16.5" rotors will probably not fit in 20s. The 6/16/20 '21 GLE order guide I'm looking at still lists larger perforated front rotors for the regular GLE with AMG exterior package. Anyone have a newer one that says something different?
Old Dec 3, 2020 | 09:18 PM
threeMBs's Avatar
Above picture is 53 with 63 brakes. I'm more talking about 450 (since there was a mention that 20" wheels from '20 450 "AMG" exterior will fit 53/63 because of the same rotors). This is the link to pictures of '21 450 "AMG" exterior: https://www.autonation.com/cars/4JGFB5KE3MA315493
The rotors are not perforated and clearly much smaller than on 53 and on '20 450. The image is below:
Specs for above '21 GLE450 "AMG" exterior state front rotors are 14.8" (may be an error, but pictures do not lie), while we now know that 53's front rotors are 15.8" (63's 16.5" are $2,500 option on 53 or part of $5,000 package). So the only way to know if 20" wheels that fit MY '20 450 "AMG" will also fit 53 is if '20 450's front rotor is in fact also 15.8" and not 14.8".
Old Dec 3, 2020 | 09:50 PM
Ron.s's Avatar
I was skeptical at 20’s fitting on the 16.5” but as I said-you can order a 53 with the 20’s with 16.5” disc’s as long as it’s the 10 spoke wheel with performance y rated tires. I saw it with my own eyes as my SA input the options. But if you switch to the Night Package 21 or 22 are required. I assume that’s because there is no black 20” 10 spoke wheel.
Any day now... maybe any week😣 I can try the 20’s on my 53.
Edit- The AMG exterior 450 & the base 53 have the same brakes. The non AMG 450, 350 have smaller brakes.
Old Dec 3, 2020 | 09:54 PM
TempeAndy's Avatar
'21 GLE 580, '20 Cayenne Turbo
The "MAY 13 WHATS NEW 2021 GLE FROM DEALER ORDER GUIDE" still shows "Sports brake system with perforated front brake discs, larger brake size and brake caliper trim with "Mercedes-Benz"lettering" under DG1PKG (the AMG exterior package that is standard on the 580).
But I just compared the '20 to '21 GLE brochures, and the AMG Line Exterior no longer states "sport brake system" like it did in '20. I would be seriously disappointed if that ends up being true. A big reason we upgraded to the 580 was to get the better brakes. It is inexcusable to have such a downgrade, while raising the price from the '20 models. And I've been reading this forum for months leading up to ordering the car and this is the first I've seen of this, somehow.
Old Dec 3, 2020 | 10:01 PM
threeMBs's Avatar
Ref: '21 450 "AMG" - do not look in brochures , visit one of your local dealers, they do have '21 450 "AMG" in stock (depending on location of course). Look at the brakes. It is clear brakes are NOT what was in the first year of production.
Ref: '21 580 - no idea. Did anyone actually see one on a lot?
Ref: '21 53 - IMO, 20" wheels (even those from '20 450 "AMG") will not fit 63 and will not wit 53 with optional 63 brakes. If configurator is correct (I said IF), 21" wheels (which are the smallest standard on 63) are required on 53 with 63 brakes option.
Old Dec 3, 2020 | 10:02 PM
Ron.s's Avatar
I missed that...no mention of the brake upgrade on the 2021 with AMG body. I would check with the Dealer that would be an unexpected & unpopular change.
Old Dec 3, 2020 | 11:19 PM
E320
Glad to see that other people are as obsessed with making sure that specific wheels fit with the various brake disc and caliper size options. I sure am learning a lot from all the discussion. For what it's worth, one can not order a GLE63 with 20" wheels. Only 21" and 22" are options. Additionally, if you choose the upgraded brakes on a GLE53, you can no longer get 20" wheels, only 21" or 22". I think I'll go ahead and try to get 21" wheels that are also a little narrower because the matching tires will be better in the snow and cheaper too.
Edit - Sorry threeMBs. Just noticed that you already made this point above.
Old Dec 4, 2020 | 06:26 AM
Ron.s's Avatar
You can order a GLE 53 with the 20” 10 Spoke wheels and the AMG Dynamic Plus Package with the larger brakes. The Dealer must also select the summer Y rated tire RO..?. The online Configurator has no 20” option but the Dealer Netstar system is obviously the final source for what’s really available.
I’ve been researching AM and the 21’s have by far the fewest winter tire options . For example the Michelin Pilot Alpin 5 SUV winter is not available in 21 or 22”, Mercedes sizes. Some of the most popular winters are already sold out for this season.
20” wheels and tires have the most high rated winter tire options and at decent prices. 22’s are also more plentiful than 21’s but still with somewhat limited tires at nearly double the price. For winter I’m comfortable with H (130 MPH) speed rated winter tires...won’t be driving 150 mph so I don’t need V,W, or Y’s.
Old Dec 4, 2020 | 09:16 AM
threeMBs's Avatar
Let me try this way.
W166 ML/GLE63 with 15.4" rotors (calipers look very similar in size and shape to V167 GLE63 calipers) were available with minimum of 20" wheels. Mercedes did not have any 19" wheels to fit the front of the car. I know that almost all aftermarket 19" wheels did not fit the front. There were, however, a few 19" that did. For example TireRack carries OZ Cortina 19x9 et30 that does fit (but 19x10 even with spacer does not due to inner shape, read on). I tried 19x9 et30 wheel on, it fits with about only 2mm, if that, of space available between outer barrel and caliper's side (you drive in snow and when it gets into that gap and freezes - forget about it). The point is that it is not only about the diameter and offset, but in this case with oversized rotors and calipers, it is also about the shape of wheel's barrel. However, even in that rare instance when 19" did fit, it would be still unusable in snow as mentioned above.
V167 63 rotors are 1.1" larger than W166 63 rotors and based on my experience with 19" wheels for W166 63, I speculate that most, if not all, aftermarket 20" wheels will not fit V167 GLE63 (or 53 with 63 brakes). And even if there's a 20" wheel that does fit V167 63, it will be useless in snow because there's not enough clearance space between barrel and caliper once snow or dirt get there.
Old Dec 4, 2020 | 01:20 PM
Ron.s's Avatar
It would be very rare that any snow or ice could build up as described. The tire warms the wheel and braking warms the calipers. Maybe at the North Pole! Centrifugal force is also throwing slush or snow off.
We will see how much clearance there is soon. My only concern would be that a piece of gravel (just the right size) might lodge and scrape between the Caliper and wheel...also possible but very unlikely. Even then damage would be cosmetic.
I’ve spent over 30 years driving in all winter weather conditions almost every weekend. Slush can build in the wheel wells but just never had it stick much less build up on the wheel....ever.
Old Dec 4, 2020 | 10:05 PM
E320
Anyone know the bolt pattern for the 2021 GLE63 if I try to get aftermarket wheels?
