Mounting EZ Pass (with AR option)
Old Aug 29, 2021 | 08:42 AM
Daso's Avatar
2021 GLE 63
This might be a really stupid question, but I'm being really cautious as I did the ceramic tint on all glass (amazingly happy) and don't want to mess up the windshield trying to pull off EZpass adhesive strip if I place in wrong spot. Since I have the AR option, is there a way to find out if I'm blocking any of the cameras behind the rear view mirror before committing? Would appreciate if anyone with AR and EZpass would share their mounting spot.
Old Aug 29, 2021 | 09:44 AM
oscarleo's Avatar
GLE 450
We have AR and acoustic glass. Had trouble with having EZ Pass read at tolls, etc even though we mounted at owner's manual recommended spots. Ended up getting the license plate mounted EZ Pass. No more worries.....
Old Aug 29, 2021 | 10:49 AM
Daso's Avatar
2021 GLE 63
i guess I didn’t read enough of the manual. Thanks will check there first but the license plate mounted one is new to me so I’ll have to check that out too. Thanks.
Old Aug 29, 2021 | 01:46 PM
zengshengliu's Avatar
2020 Mercedes GLE 450
I have no issue placing the EZ Pass at the center lower portion of the windshield (I also have the acoustic glass). Take a flashlight and shine it toward the location. You will see the "dotted" area where you suppose to mount the transponder.
The other spot is on the right side of the mirror. I didn't put my EZ Pass there because I mounted a dashcam (with GPS) at that location.
Old Aug 29, 2021 | 11:52 PM
maalox's Avatar
I also put mine in the center lower position, but I never actually stuck it to the windshield. I got one of these
Amazon Amazon
because I dislike the look of the ugly "white" EZPass transponder. The sleeve makes it rubbery black and just leaving it on the upper dashboard, wedged between the windshield, seems to work fine. I occasionally notice it that it moved left or right by a couple of inches (which with the acoustic glass means it probably won't work), but I don't drive EZPass roads that often and nudging it back to the center takes a second.
Old Aug 30, 2021 | 12:02 AM
Daso's Avatar
2021 GLE 63
Originally Posted by maalox
I also put mine in the center lower position, but I never actually stuck it to the windshield. I got one of these https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 because I dislike the look of the ugly "white" EZPass transponder. The sleeve makes it rubbery black and just leaving it on the upper dashboard, wedged between the windshield, seems to work fine. I occasionally notice it that it moved left or right by a couple of inches (which with the acoustic glass means it probably won't work), but I don't drive EZPass roads that often and nudging it back to the center takes a second.
Thanks to both of you. Appreciate the help.
Old Aug 30, 2021 | 02:05 PM
Lucky 777's Avatar
Top Answer: 1
2024 GLE 450 4matic
I have the same sleeve on my EZ Pass. It mounts on the windshield in the sweet spot and basically disappears...much better looking than the white plastic.
Old Aug 30, 2021 | 03:38 PM
Daso's Avatar
2021 GLE 63
Thanks, I ordered it
Old Sep 1, 2021 | 06:56 PM
jtjbt20x's Avatar
2021 GLE450W4 SUV
It took me too long to find the RF transparent location next to the rear view mirror and I had to get within a few inches of the windshield from the inside before I could see it; I never found the center dash location.
Here are four pictures. Three are looking at the windshield at different magnification levels. The other is taken from the inside looking through the windshield with the grid of the RF transparent location.
Zoomed out.
This is the grid in the RF transparent section. The double white rod are the fluorescent lights on the ceiling.
Zoomed in a little bit more.
Zoomed in max.
Old Sep 1, 2021 | 08:34 PM
Daso's Avatar
2021 GLE 63
Zoomed out.
Zoomed in max.
awesome, Thanks.
Old Sep 2, 2021 | 08:35 AM
MarkerVB's Avatar
2021 GLE 450
I didn't have a problem locating the areas quickly from the outside using my phone light, with the car in the garage.
Old Aug 9, 2023 | 03:51 PM
digital_b's Avatar
2026 E450
although another member helped me with my issue regarding this in my GLE 450 I am saying thank you to you for this which I just confirmed because mb phone customer service it horrific now. I did the flashlight method of finding the 2 spots on my windshield so I will be dropping off my plate mount abomination and getting the proper transponder tomorrow. thank you very much.
Old Aug 10, 2023 | 06:41 AM
user 7208224's Avatar
2020 GLE 350
I use one of thesex
Amazon Amazon
I have it to the right of my mirror. It is easy to remove to clean the glass. I have AR.
Old Aug 10, 2023 | 08:01 AM
TonyF61's Avatar
2022 GLE 450
You don't need to mount it..
You can go to EZPass online and register your license plate. The toll readers/scanners will look up your plate number and bill you as if you used EZPass. If you ever get a violation, which you shouldn't, all you have to do is call them and have them verify your plate is registered. They will remove violation.
Old Aug 10, 2023 | 11:25 AM
z28lt1's Avatar
C450, GLS 63 and a few other things
While this works fine in some locations, it is a terrible idea in others.
Where I am, a decent portion of toll booths still have gates, so without the EZ-Pass, you've got to wait for someone to open it for you.
In other places, if your EZ-Pass doesn't read, they will charge you the toll-by-plate rate which is often higher. For example, the NY Thurway specifically calls this out:
"NOTE: E-ZPass customers who do not properly mount their E-ZPass tag (tag), which results in their tag not reading properly while traveling on the Thruway, will be charged the Tolls by Mail toll rate. The Tolls by Mail rate is 30% higher than the E-ZPass NY toll rate. This is due to the time and cost associated with the process to identify vehicles that do not have the tag properly mounted or not detected in the vehicle."
Old Aug 10, 2023 | 03:20 PM
TonyF61's Avatar
2022 GLE 450
I can accpet that some tolls still have gates;; although a little old-school. However, I have 6 members of my family on my NY EZPass account. We all have plates registered, because I was told, years ago, that the max tags on a residential account is 5. I even put myh sister-in-law from NC on there because she travels here now and then. She will occasionally get a violation mailed to her. All I do is call EZpass and they charge me the tag rate and void the violation. HAven't seen any gates in NYC in a while. Doesn't mean they don't exist.
If your concerned about it, then mount it where the manual states, or get the one that mounts on the license plate, which IMO, is likely to get stolen.
By the way, mine is mounted as manual shows, and I do occassionaly see "TAG NOT READ" when I pass through toll, but never receive a violation, nor higher toll rate. I don't even have a front license plate. GLE looks so much better without it. Well, I do, but it is a "flip" plate that folds up from under the bumper when I need it to.
Old Aug 10, 2023 | 04:40 PM
mikapen's Avatar
I agree. There's a difference between regions and States that have a cooperative agreement, but all mine charge more with license detection, even though I have my plates associated with my tag. (At least until an email I got from one last week, saying that they can now associate plates with pass tags.)
For the three co-op areas I drive in, there's no transponder, just a small tag applied inside.
I was pretty sure I had found the space in the IR windshield, but my last trip resulted in all license plate detections.
They sent new tags and advise that I put them in the sunroof, at the leading edge.
Old Aug 10, 2023 | 11:21 PM
If you are re-using a old EZ-Pass and its over 10 years old, there is a chance that the battery inside is running low.
EZ-Pass has a non replaceable battery that last about 10 years. After that, you might start getting the "tag not read' issue. I have to contact the agency to get a free replacement.
Old Aug 11, 2023 | 06:46 AM
TonyF61's Avatar
2022 GLE 450
They replaced all my tags last year. It seems to be one specific toll plaza that gives me the error. It is; however, the most convienent one for me. No impact on me, so it doesn't matter; I just find it odd.
Old Aug 13, 2023 | 01:27 PM
Alan M's Avatar
MB GLE 450e, MB S 580
in the sunroof
I have always put my Sunpass in the sunroof - it can not be seen and it works !
Old Aug 13, 2023 | 03:10 PM
jtjbt20x's Avatar
2021 GLE450W4 SUV
How do you mount it?
Old Aug 13, 2023 | 03:28 PM
Alan M's Avatar
i mount the pass with the suction cups- been doing this for 10+ years on many cars
Old Aug 13, 2023 | 05:50 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
EZ Pass
Those things are UGLY, especially in white. Glad we don't have tolling here, but they're talking about it.
Old Aug 13, 2023 | 08:50 PM
Same, especially the reflection on windshield.
This is why I got the cover for the ez-pass, and mount it at the bottom.
https://a.co/d/iVZsYuI
Old Aug 14, 2023 | 07:02 AM
TonyF61's Avatar
2022 GLE 450
That is much nicer looking.
