Distronic with Illuminated Star
I've asked Raj at RJ Automotive as well but thought someone here may have first hand experience. Thanks in advance.
Well, given no feedback or comments I guess no-one has had this situation or it’s not an issue. Kind of weird though that MB doesn’t let you order the illuminated star with Distronic then, although I realize that when you order the Distronic pack the star itself is different.
I didn’t order this car, it was off the lot, and I’d not have added the star myself but the car came with augmented navigation and a few other options that we did want. In between seeing the car and buying it I checked on refitting Distronic and only bought the car having found that it is possible.
I am assuming the reason why MB don't offer illuminated star for distronic equipped vehicles due to this reason, it is flush, I guess they can illuminate the ring but it can't illuminate the actual star due to the amount of radars and sensors within the emblem.
I believe (not fully sure) it uses that radar and the camera used for augmented reality or the camera right above the star (although that is likely just used for the 360 camera function), cars without distronic can option auto brake (my C43 without distronic has auto brake although distronic brings the full active brake assist). That camera near the top of the windshield also helps with the intelligent light system to automatically turn on and off highbeam when it senses traffic and if you have adaptive high beam assist plus it turns off individual LEDs while keeping the rest of the high beam on.
DISTRONIC star
https://www.logolynx.com/images/logo...f8dc62fd4.jpeg
Pre-2019 non-DISTRONIC star
https://i.ebayimg.com/images/g/EOcAA...~9C/s-l300.jpg
Post-2019 non-DISTRONIC star
https://i.ebayimg.com/images/g/TZkAA...4Ju/s-l400.jpg
DISTRONIC star
My personal experience with LED bulb on garage door opener is that those does interfere with the garage door opener which decrease the range (even those specifically designed for garage door opener still affects the range, just not as bad as non garage door model), so I wonder if the same thing applies to the LED on the illuminated star which might interfere with the long range radar used with the Active Distance Assist DISTRONIC.
It looks like what you are activating is the distronic PRO, not distronic PLUS. I believe only the PLUS uses the long range radar, so you might now have issue with the PRO one.
There are 2 Versions of Distronic in modern cars, Distronic PRO & Distronic Plus.
The main differences are:
- Distronic Plus uses a Long range radar sensor & requires the flat MB heated "distronic" star as everyone calls it.(except in the w213 where distronic pro also uses this star) Distronic plus is always bundled with driver assistance pack. This distronic has extra features such as cross traffic assist & works at a higher speed (100mph+)and longer range. For short range detection the stereo camera is used.
- Distronic Pro uses the already installed CPA radar in all modern Mercedes vehicles (except 205/253/213). This is a mid range radar sensor so it does not require the special "distronic MB star" and can work with the standard 3D star, even if illuminated. Distronic PRO is adaptive cruise control only, however in my opinion works just as good as distronic plus, in traffic even comes to complete stop and takes off again.
In some European markets Distronic PRO is offered as a option when configuring the vehicle, however in the UK for example MB force you into spending more money on driver assistance pack.
To retrofit Distronic Pro in a vehicle with a CPA radar all that needs changing is the steering buttons & then some coding which we can do remotely.
I hope this clears things up
Regards,
Raj
I mean the codes of what you took and then what solution you adopted since I imagine the distronic needs to be moved.
ps. sono italiano anche io!
