OEM Floor mats
Old Jan 12, 2023 | 04:35 PM
bujjodu's Avatar
C230 Kompressor
Floor mats I got OEM. I want to get a cargo liner, after seeing your comments and other comments about cleated design on OEM cargo liner, I started checking on tuxmat and Weather tech. I like the weather tech design, but I read many comments from many folks saying good things about tuxmat,
Old Jan 12, 2023 | 04:41 PM
HotRodW's Avatar
2021 GLE450
If you want to use grip retainers, I recommend going with WeatherTech. I use WeatherTech retainers on my TuxMat, and they hold okay, but not as well as they held on the WeatherTech mat.
Old Jan 12, 2023 | 10:34 PM
hutch300's Avatar
2022 GLE450
I like my Lloyds rear mat and floor mats.
Old Jan 15, 2023 | 02:16 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Originally Posted by HotRodW
I replaced my 450's OE tray for a Tuxmat. Good quality and the coverage extends all the way to the hatch. It's not as grippy as the more rubber-like cleated OE mat, which is both good and bad. The photo below was taken right out of the box. The mat has since flattened out nicely. You'll find another thread on mats here.
I think I am one of the first people here on this forum who used the tuxmats. I have them in all of my vehicles but I will never replaced the hard liner coming from the manufacturer as it won't take the beating and abuse when you throw something hard and sharp on the tuxmat trunk liner. Drag something sharp and heavy and that thing will rip-off so be aware of the limitation of the tuxmats. I was given a test sample of that mat as I am a distributor of the mats to test out and when I dragged my 70lb e-bike across it, it damaged the top layer were as on the hard MB liner it just glided with ease and took the abuse like it was nothing. Take note I drag 3 ebikes on the GLE's back every week since spring last year and the liners still look like new. Also if you look at the design of the tuxmat's liner it will never hold any liquid not like the MB liner which is actually a small tub. The small lip on the MB liner has saved my interior a few times already when leaking juice box and crushed milk cartoons started spilling out liquid which I don't believe the tuxmat liners will do. On the ML I know there is a high tub liner available not sure on the GLE. These combo is 100% tested and proven to take the abuse base on how I use the back of the GLE. Anyone who is constantly putting heavy objects on the back should have these two especially the load sill protector.
Old Jan 15, 2023 | 02:54 AM
Has anyone tried Tuxmat cargo liner for GLE350 ? if not any good recommendations for cargo liner
Depends on what you think you will put on the back of the trunk and expectations of protection. For looks go with the tuxmat but for utility go with the MB liners as they will take the abuse and will store some liquid in the liners and won't spill to the tail gate when you hit the accelerator.
Old Jan 15, 2023 | 02:58 AM
Where did you buy tuxmat ? From there website or Amazon or any other place.
If you are buying the tuxmats make sure to give the company a call first BEFORE ordering it online (amazon or direct). This assures you there is stock available. I would also suggest to go through the amazon route as well as it gives the buyer "more" options when returning a defective product.
Old Jan 15, 2023 | 03:02 AM
  #32
To those thinking what the tuxmat looks like on the GLE here it is. There is another thread that someone replaced the tuxmat badge with a AMG logo on it. If you have a 3rd row option these mats are perfect to protect the back especially if you have kids at the back.
Old Jan 15, 2023 | 08:55 AM
  #33
HotRodW's Avatar
2021 GLE450
The durability of the OE mat wasn't the issue, it was the cleats and how they prevent items from sliding even when you want them too. Sliding a box or crate can be a challenge, and the more the item weighs the more difficult it becomes. The design makes the OE mat great for transporting, but lousy for loading/unloading. I kept my MB mat, but I doubt I'll ever use it again. If the TuxMat ever fails on me, I'll buy a WeatherTech to avoid the frustration.
Old Jan 15, 2023 | 12:14 PM
  #34
jaxslk's Avatar
2025 GLE 450, 2022 AMG GLE 53
That was me. Pics here:
https://mbworld.org/forums/gle-class...ml#post8600228
I also use oem for the rear cargo area. TuxMat just for front and middle. Love the Tuxmats.
Old Jan 15, 2023 | 12:19 PM
  #35
bujjodu's Avatar
C230 Kompressor
Thanks for all great responses and posting pictures. For OE liner, is there any place we can order other than going to the dealership and buying from them ? I decided to go with either Weather tech or OE liner. Weather Tech Cargo liner is available only from weathertech.com and they are charging $134 and no free shipping. I did not call the dealer yet about the pricing of OE liner.
Any other places I should check ?
Old Jan 15, 2023 | 02:03 PM
  #36
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Cargo mat
There is also this OEM reversible cargo mat.
Old Jan 17, 2023 | 01:47 PM
  #37
There is a trick I do when I load heavy things on the OE mat. I put a towel under the item I load then it just slides easily. When I want to remove the item from the back I just pull the towel and it will slide out without a hassle. You will surely add a cover or something when you put a heavy item on the tuxmat liner so try that trick. The moving guys have a blanket that they use for moving so see if you can get one or just get a extra large towel. If you use a milk box or any of the foldable box trays it catches perfectly on the OE liner's extrusions and it won't make the box move.
Old Jan 17, 2023 | 01:54 PM
  #38
You can go eitherway as both are almost the same. The OE has the MB logo on it. Just go with the one that is cheaper and easier to get. I am not sure if weathertech is like the MB's liner that have lip on all sides. If you are thinking of liquid spill and the weathertech has a flat side on the bumper area I would go with the OE liner as it is considered as a shallow tub design.
Old Jan 17, 2023 | 03:03 PM
  #39
bujjodu's Avatar
C230 Kompressor
Thank you. I went with Weather tech. I did not like the cleats design on OE liner. I will check weather tech Once I get it, If I don't like it I will go with OE liner.
