2024 GLE 450 wheels
Old Oct 18, 2023 | 04:16 PM
AF23's Avatar
QX35
2024 GLE 450 wheels
Does anybody have the 20 inch twin 5-spoke wheels on a GLE 450. Does it look different from the AMG 20 inch twin 5-spoke version?
Old Oct 18, 2023 | 04:49 PM
BlueYonder's Avatar
2024 GLE 450, 2009 SLK 300
If you get the AMG appearance package on the GLE 450 they are the same.
Old Oct 18, 2023 | 04:55 PM
AF23's Avatar
QX35
do you have photos
Old Oct 18, 2023 | 05:55 PM
HotRodW's Avatar
2021 GLE450
They're up on the configurator.
Standard:
Night Package:
Old Oct 18, 2023 | 06:00 PM
HotRodW's Avatar
2021 GLE450
And here is the non-AMG 20" twin 5-spoke wheels. I suspect this is the wheel you're asking about?
Old Oct 18, 2023 | 06:06 PM
AF23's Avatar
QX35
Yes - I think I ordered the 5-spoke thinking it would look like the AMG. I get the twin 10-spoke looks better than the twin 5-spoke.
Old Oct 18, 2023 | 07:41 PM
AF23's Avatar
QX35
Spoiler
Old Oct 19, 2023 | 10:16 AM
AF23's Avatar
QX35
Does the 19 inch tires look any different than 20 inch or ride differently
Old Oct 19, 2023 | 10:35 AM
wildta's Avatar
GLE 580
A lot of folks on here have complained that the 19" looks too small for the vehicle and the wheel gaps are very big and noticable. Not sure about ride.
Old Oct 19, 2023 | 01:51 PM
AF23's Avatar
QX35
Thanks - I switched to the 19 inch 10-spoke because I am not crazy about the 20 inch choices of the twin 5-spoke or twin 10-spoke rims.
Old Oct 19, 2023 | 01:59 PM
AF23's Avatar
QX35
Are MB tires run flat? Is the 19 inch that comes with the GLE 450 a run flat tire? Is the 20 inch a run flat?
Old Oct 19, 2023 | 02:49 PM
BlueYonder's Avatar
If you get the third row seats or the hybrid, you get runflat tires or a Tirefit kit (sealant goop and a pump).
My GLE450 came with the 5 spoke AMG 20" wheels. The tires are Michelin Primacy Tour A/S
Old Oct 19, 2023 | 04:01 PM
AF23's Avatar
QX35
I guess you got the AMG package with your GLE 450. I did not.
Old Oct 19, 2023 | 04:15 PM
AF23's Avatar
QX35
I do not have a 3rd row and did not get the AMG package so I could not get the AMG tires. I could get the 19 inch that came with it or upgrade to the 20 inch twin 5-spoke or twin 10-spoke tires. I think all are run flat tires.
Old Oct 19, 2023 | 06:48 PM
BlueYonder's Avatar
You need to download the order guide posted on this site. You only get run flat tires if you get the 3rd row seats or hybrid. This is because there is no room for a spare. It doesn't matter what the wheels are, the tires are the same.
Old Oct 20, 2023 | 04:03 PM
BenjaminKohl's Avatar
2014 Mercedes E350 4matic Wagon, 2018 Fiat 124 Spyder Lusso manual, 2005 Acura TSX manual
For the 2020-2023 model year, the 19s came on smaller size tires. They had the same aspect ratio as the 20s, 50, so between the smaller width and smaller rim, they were much smaller. The 275/50/20s had (have) a 30.8 inch tall tire and the sidewall is 5.4 inches, where as the 19s, 255/50/19s, only had a 29 inch tire and 5 inches of sidewall on each side. So an inch less rim, but almost 2 inches less total tire height and less sidewall. Now for 2024, the 19 inch wheel comes on a 275/55/19 tire, so the overall tire height is the same at 30.8 inches, and the sidewall goes to 5.9 inches per side. It is a straight tradeoff between an extra inch of tire or rim.
Check out the order guide to answer all your questions, but on a two row gas GLE350 or 450, they have a full size spare tire and no runflat tires, which is an amazing thing.
Old Oct 20, 2023 | 07:38 PM
mikapen's Avatar
Good post.
Do you mean "temporary spare" that's inflated, but is a skinny 155 X 19 or similar size?
Old Oct 20, 2023 | 07:47 PM
HotRodW's Avatar
2021 GLE450
As it should be. I still question why this wasn't the answer when the 167 launched.
Old Oct 20, 2023 | 08:47 PM
Originally Posted by mikapen
Good post.
Ah, I believe you're right. I thought the GLE had the full size spare and the GLS had the temporary spare but it looks like the GLE has the temp spare and the GLS has the "collapsable" spare.
