High revs at cold start
Old Nov 26, 2023 | 04:37 PM
jonpom's Avatar
08 GLK350, 10 E350, 12 R350, 14 CLA250, 18 E400 Coupe, 20 GLE580, 21 GLC43, 21 GLC300, 24 GLE53 SUV
Does it matter if tranny is engaged while revs are initially high at cold start or is it better to wait until RPMs settle down? I usually wait. What do others do?
Old Nov 26, 2023 | 04:42 PM
chrislk55's Avatar
2023 GLE63S - Edition 55
Sometimes I wait if I'm not in a hurry, sometimes I just let it warm up for a minute or so then go. I do watch my RPMs and avoid any spirited driving until the oil and transmission fluid temps are in the white zone.
Old Dec 15, 2023 | 01:33 PM
W205C43PFL's Avatar
I wait till it revs down, I think that is healthier for the transmission, but it might be negligible.
Old Dec 15, 2023 | 02:48 PM
mikapen's Avatar
The best way to warm up a vehicle is not at idle. Instead it's under a low load, as in driving gently.
The reason - it comes up to operating temperature more quickly and that's a better state to be in, as an engine.
The only reason to delay driving, is to make sure that oil is circulating throughout the engine, which only takes a few seconds with modern oils.
I agree on watching the transmission and oil temperatures before racing around. The tranny takes a while.
Old Dec 15, 2023 | 03:48 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
On transmissions with a torque converter the difference between engaging at high cold idle and warm idle is not significant. The slight difference in speed will simply be absorbed by the converter. Certainly wouldn't recommend neutral drops or launches with a cold engine/transmission but driving normally is a non-issue.
Old Dec 15, 2023 | 08:08 PM
W205C43PFL's Avatar
Yup, some forum members suggested putting it in manual and sport+ and upshift in good time to keep it at low RPM, apparently sport+ heats the transmission up faster, which helps in winter especially how highway driving takes like 1 hour to heat up but I sitll don't recommend that.
Old Dec 15, 2023 | 08:59 PM
Ron.s's Avatar
2024 GMC Canyon Denali..... 2018 Audi SQ5
As I recall, the GLE 53 doesn’t have a torque converter like a normal automatic. (Nor any other Mercedes with the ISG.) The ISG, licensed from Continental, eliminates it. Some other ISG’s might still use a TC.
Old Dec 16, 2023 | 11:31 AM
mikapen's Avatar
The 53 has a torque converter transmission, TCT
The 63S has a dual clutch transmission, DCT.
After putting my TCT through its paces yesterday, I think AMG did a fine job on their Speedshift TCT!
(Boy does that little 6 pull hard at 135!)
