Service A Now Low Oil
If that doesn’t work then a call to the Service Manager might be the next step. Maybe that call should be step one throwing out options.
It sounds like they owe you a quart of oil that you paid for and didn't receive.
The answer you got back from the Dealer is BS, IMO. They come from the factory at full…at least all of mine were.
@bkushner - I definitely agree with you, in that I would feel "short changed," no pun intended
Happy Motoring!
I suppose it's possible that your initial reading was skewed low, as a result of the vehicle not being parked with engine at idle. [insert shrug emoji] I could be totally off base with this assumption, but I'd hate for you to add oil if the level turns out to be correct (full), once you re-test.
Good luck!
Good luck!
While I don’t have Mercedes experience beyond the above, my Jeep GC WK2 always had oil at MAX after every service, so this “normal for the season” argument seems made up.
