Help! Keep or unload MBZ w/r/t P06DA00
Old Oct 16, 2024 | 09:28 AM
NOVAMBZ's Avatar
Greetings from Northern Virginia! My 2020 GLE 4-matic has a check engine light on. In short, my independent mechanic has said it is a P06DA00 code. My GLE has under 50,000 miles. Key points below:
- this code requires the replacement of a $95 piece but to get to the piece, the engine has to be taken out. He said it is about $3000-$3500 worth of work - it is all labor.
- my independent mechanic said go to a MBZ dealer and see what they say and then see if MBZ corporate will cover the cost (or some portion of it). he said any chance for MBZ corporate intervening will have to come with the car at a MBZ dealer. he said this work would normally be covered under warranty but even though my car is out of the timeframe of warranty, it is under mileage.
- anyone deal with this code issue? if so, what was the conclusion and cost?
- I also own a 2024 GLS 450. I love MBZ. However, if I am looking at eating $3-5K in cost for this I will not do the work and sell the 2020 MBZ and trade it in for a Lexus (I also own a 2015 Lexus and runs like butter - no problems).
The worst part is my mechanic does not think this code issue will impact my car but to pass emissions test I need to have the check engine light fixed.
Thank you in advance for any information/advise!
Old Oct 16, 2024 | 06:48 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to V167 forum...
Old Oct 16, 2024 | 07:39 PM
JettaRed's Avatar
Veteran: Army
HOLY COW!!! Read this thread: https://mbworld.org/forums/w212-amg/...solenoids.html
The conclusion is to ignore it (per Mercedes instructions). If the CEL bothers you (it would me), buy the part and connect it externally to the cable harness. All the info you need is in the thread.
Old Oct 16, 2024 | 07:44 PM
JettaRed's Avatar
Veteran: Army
The red heat shrink was added since the part sits on the front of the engine.
Old Oct 16, 2024 | 07:53 PM
JettaRed's Avatar
Veteran: Army
P06DA00 is a code set for a malfunctioning oil pump solenoid whose sole purpose is to artificially restrict oil pressure (and oil flow) in the interest of reducing the energy it takes to circulate oil and therefore save miniscule gas mileage. It's all in the thread I posted above.
Old Oct 16, 2024 | 07:57 PM
JettaRed's Avatar
Veteran: Army
OK, attaching the decoy solenoid to the wiring harness will tell the ECU it has a working solenoid. The DTC can be cleared and the CEL will turn off so you can pass inspection.
Old Oct 16, 2024 | 08:36 PM
W205C43PFL's Avatar
https://cimg1.ibsrv.net/gimg/www.mbw...a90cc2487f.png
https://cimg7.ibsrv.net/gimg/www.mbw...401271ac62.png
Hmmm, certainly unusual for that oil pump solenoid to fail so early.... on a 2020 vehicle.
Old Oct 16, 2024 | 08:57 PM
JettaRed's Avatar
Veteran: Army
I would like to know what engine the OP has. Do the new 4-bangers use the same oil pump design?
Old Oct 16, 2024 | 09:31 PM
W205C43PFL's Avatar
That is a good question, M274 is affected for sure I think M264 I heard too was affected, not sure about M254. To clarify what I meant affected as in does have this 2-stage oil pump solenoid.
Old Oct 17, 2024 | 10:55 AM
BlueYonder's Avatar
2024 GLE 450, 2009 SLK 300
Have you checked to see if it is covered under the 8 year/80,000 mile emission warranty?
Old Oct 17, 2024 | 02:42 PM
W205C43PFL's Avatar
I am concerned with the state of the valve, is it jammed stuck by chance, if so then definitely get it repaired.
Old Oct 17, 2024 | 03:54 PM
JettaRed's Avatar
Veteran: Army
One way to check is to connect a pressure gauge to the oil diagnostic port IF his engine has one. On the M276 it is right next to the oil filter housing. If the pressure is above 2 bar at less than 3500 rpm, the solenoid is not stuck. If the pressure remains less than 2 bar at 4000 rpm, then it is stuck in the wrong position.
Old Oct 17, 2024 | 04:00 PM
JettaRed's Avatar
Veteran: Army
File Type: pdf
Old Oct 17, 2024 | 05:29 PM
W205C43PFL's Avatar
https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/1570x830/image_d27718b21a42d4dabcf0aeaddce36ab5fcf2dfcd.png
https://cimg1.ibsrv.net/gimg/www.mbw...e07456d900.png
Perfect! That is a good idea : )
Hopefully OP gets that test done, once OP is done with it, confirms pressure good, just unplug it, to OP's benefit after all.
Old Oct 24, 2024 | 11:22 AM
NOVAMBZ's Avatar
Thanks to all that replied. Here is the outcome.
- MBZ Dealer quoted me $5700 to fix the issue.
- Asked if MBZ Corporate would help offset the cost given my car was still under the warranty mileage (49,000 miles)
- Dealer came back and said would charge the extended warranty rate of $4400 to fix the problem and I would be responsible for half.
- I paid $2200.
- By chance I ran into the service manager while he was smoking a cig and he said that a) if enough of these problems are reported (P06DA00) there is a chance MBZ could issue a factory recall and b) he half-jokingly said he doesn't even want the job because it is a two-day job of taking apart the engine.
- My break point was $3,000 - anything more than $3,000 I am pretty sure I was going to sell the car and buy a Lexus.
Old Oct 24, 2024 | 12:26 PM
JettaRed's Avatar
Veteran: Army
- I paid $2200.
I'm curious, did you read any of the discussions about the P06DA00 code and the oil pump solenoid? If you had, you probably would have saved $2200. I am also curious why you had to pay anything at all if the car was still under warranty.
Old Oct 24, 2024 | 01:21 PM
W205C43PFL's Avatar
Saved money as well as having the benefits it came.
Old Oct 28, 2024 | 01:32 PM
NOVAMBZ's Avatar
I did not do the oil pump solenoid because that is way above my head - I can pretty much fill up the windshield washer fluid and put air in the tires - and that's sadly about it.
The car is out of the 4 year warranty but under in terms of mileage. My mileage was circa 48,500 miles (just under the 50,000 miles).
Old Oct 28, 2024 | 01:56 PM
W205C43PFL's Avatar
I see but basically all you needed to do is instead of "fixing" it, plug a dummy solenoid in the existing connector outside of the vehicle and enjoy the benefits not having it brings. That said, since you already carried out the repair, don't want to rain on your parade, enjoy the car.
